need some help on my dvd stereo
Old Jun 3, 2007 | 01:39 AM
  #21
THUGLUVC.A's Avatar
THUGLUVC.A
Default RE: need some help on my dvd stereo
OK IVE INSTALED EVERY THING IN MY RAM 02
I JUST CANT FIND DAT DAM E BRAKE WIRE DUS ANY ONE KNOW WERE ITS AT? OR WAT COLOR IT IS
Old Jun 3, 2007 | 03:32 PM
  #22
HuntinHanson's Avatar
HuntinHanson
ORIGINAL: FFMedic1479
Use solder... you will thank yourself in the long run... I have used the butt connectors with success in the past, but I have had them come loose even with proper crimping and tape. That, and I think it is just a cleaner job. To solder properly takes practice, but it isn't rocket science. Let your soldering gun get up to temp, put a little dab of solder on the tip and directly place it where the two wires that you are joiningare twisted together (make sure you cut back enough of the insulation that you are not melting it in the process, probably around 3/4" on both sides). Then from the top of the wires, place your solder onto the wires, letting it "infuse" into the wires. There shouldn't be a whole lot of flux or discolored solder, it should be shiney and smooth along the wires. Then wrap the whole thing in a layer of electrical tape. It actually doesn't take much longer then the butt connectors, and there isn't all that extra plastic bulk behind your radio that you will have to mash and manipulate to get the head unit in.
soldering is the best way to go and i would never advise against it. The only reason i havent done it on my stereo is every time i solder somthing it seems like i don't have enough hands. But it does give a great connection. I've never had problems with a butt connector and electrical tape though.
Old Jun 4, 2007 | 05:36 PM
  #23
FFMedic1479's Avatar
FFMedic1479
ORIGINAL: HansonHVAC
I know exactly what you mean... I have always used a harness adapter when installing a head unit, so you can do it sitting at your kitchen table... it gets more difficult when wiring in the truck. That and I would get nervous having the hot soldering gun around all of that plastic and cloth in the interior of the truck.
Old Jun 5, 2007 | 05:12 AM
  #24
austin's Avatar
austin
So why would I need both harnesses? By the way with the harnes do you still have to strip and solder, or is it really "plug and play"??
Thank you guys!
Old Jun 5, 2007 | 03:20 PM
  #25
HuntinHanson
I don't understand why you would need both harnesses? that doesnt even make sense? theres only ONE plug behind the radio. On the harness and your new radio you need to strip back the wiring and connect them to each other. Then you plug the harness you bought into the one that was connected to your factory radio
Old Jun 5, 2007 | 04:08 PM
  #26
FFMedic1479
Yeah, not too sure about the two differant harnesses. You should just need the adapter harness for your year and model truck... on the bag that the harness comes in has the color code for the wires (such as right rear negative is black with yellow stripe... I don't know if that is true, just an example), then you take your head unit out of the box, take the harness that comes with that head unit, and open the directions, the directions will tell you (might be marked on the wires too) the color codes for the aftermarket head unit harness (such as right rear negaitive is violet with green stripe)... all you have to do is match up the correct wires, stripping back the wire if you have to (many come pre-cut) and then you solder the two harnesses together. After it is all soldered and taped, then it is just a matter of plugging in the harness.
Old Jun 5, 2007 | 04:30 PM
  #27
HuntinHanson
usually the harnesses come in the same colors as the back of the radio so its not confusing. Everyone i've ever done has anyway. And for right rear speaker, i believe its purple lol
Old Jun 5, 2007 | 04:52 PM
  #28
FFMedic1479
I think you are right, it probably is purple come to think of it. I have run into a couple harnesses in some of my older trucks and other cars that I have done installs on that didn't match with the aftermarket head unit. Either way it is a matter of making sure you match up the correct wires.
Old Jun 5, 2007 | 08:49 PM
  #29
fannitti's Avatar
fannitti
i have the exact same tv u want to put in ur truck the jensen and it so easy to put in. get if off ebay its only 334$ a lot cheaper then 600$
Old Jun 6, 2007 | 02:41 AM
  #30
austin's Avatar
austin
hey did you install it yourself then? or with some help?
also, since you own it, how do you like it??
