door lock problem
Old May 31, 2007 | 01:29 AM
HuntinHanson's Avatar
HuntinHanson
Default door lock problem
I was putting my new speakers in and got everything wired back up. When i put everything back together i noticed by passenger rear door lock wasn't working. I'm not sure if this started happening after the speakers or before, my cuzin was complaining it wasn't unlocking this weekend i thought she just wasnt waiting til the door unlocked. But anyway, the window works, all three locks on the other doors work just not that one. It doesnt work with the keyless entry or the keypad. Any ideas?
Old May 31, 2007 | 01:38 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Default RE: door lock problem
May have just pulled a wire when you were installing the speakers. Double check that. I did the same thing when I put speakers in my other car. Got all done, and later that day while driving, I could not adjust my mirrors. Took the panel off and sure enough, I accidentally pulled a wire to the door switch.
Another easy check is to put your finger on the lock itself and hit the unlock and lock button. If you feel a pressure vibration then something is jammed. If nothing then no power getting to the lock. Meaning, either bad / unplugged wired, or bad lock mechanism.
Old May 31, 2007 | 01:44 AM
HuntinHanson
i looked at all the wires they seem to be ok. I can pull it up and down with my hand but i'll go try putting my finger on it while trying lock/unlock.
Old May 31, 2007 | 01:51 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
You'll always be able to push/pull your lock as it is mechanical with a solenoid attached. If your wires are all ok, then check for a vibration. What you might feel is the solenoid trying to pulse but if it is jammed then it will vibrate violently within the casing. You should feel it or even hear it as well. Seems like you are good wth working on your truck, so you can even try and switch the locks from one side to the other and see if the problem stays or moves with the lock. If the problems stay on the same door then break out your meter and start checking to find out where you are losing the power.
This is my best guess right now
Old May 31, 2007 | 03:09 AM
HuntinHanson
Yeah i did check for vibration and didnt have any. SOOO after about an hour of pissing around i said fuc* it and went and got my multi meter. I found i was losing power in the wiring harness behind the seat belt pillar. I pulled it apart and sure enough one of the wires was in the harness and not getting a connection, pulled it out, put it back in and now it works like a champ!
Old May 31, 2007 | 12:04 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Sucks when you have to get the meter. Everytime I get mine out, I start to think that this could turn out to be a long process cost more money on something that I did not need to spend on. Then, I find a broken or loose wire and I am happy again....
Glad you got her working
Old Jun 1, 2007 | 02:42 AM
HuntinHanson
Eh i don't really mind getting out the meter. I use it pretty much every day at work with a wiring diagram for whatever i'm working on. Its kind of become second nature.
Old Jun 1, 2007 | 10:58 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
ORIGINAL: HansonHVAC
Same here. I use mine on a daily basis with what I do. It makes some jobs much easier to troubleshoot.
