Fuel Octane?
Old Jun 16, 2007 | 10:30 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Default RE: Fuel Octane?
ORIGINAL: OldMoparMan
ORIGINAL: L and R Two
Higher octane just burns cleaner and faster thus reducing the chance of knock and tapping.
Quite the opposite....
The higher the octane, the SLOWER the fuel burns, reducing preignition on hot pistons and cylinder metal.
That's why 87 octane pings like a biotch in high compression engines, (compression causes heat: IE Diesels) because it has a higher/faster burn rate, and a lower flash point.
To boot, running high octane fuel in a car NOT designed to run it is a waste, and due to a slower burn rate, can lead to piston/valve deposits due to causing an "over rich" condition.
I ran the 91 octane program with a tank of 87 octane fuel and couldn't pull out from a dead stop without the engine pinging. With the 91-93 octane in my truck, it runs a ton better.
Yes, your right. I typed it, read it, and missed what I did. Don't know what I was thinking.
Old Jun 17, 2007 | 05:49 AM
JimmyDiablo's Avatar
JimmyDiablo
[sm=pcwhack.gif]Ceotene that is the rating to look for and add.
Old Jun 18, 2007 | 12:40 AM
Silver Eagle's Avatar
Silver Eagle
I have an 04 4x4 hemi Quad cab ThjunderRoad and I use 87 all the time. Yesterday I pulled my 5,000 lb boat with no problem and no Ping.or knock. i bought the truck new and it now has 18,000 on it. I toppedof the tank today amd my average was 14.4 That included pulling my boat 100 miles. No I wasn't using the over head computer.
Old Jun 18, 2007 | 01:55 PM
Duso02's Avatar
Duso02
ORIGINAL: jimmydaleo
If I had a CTD I would!!!!!
Old Jul 10, 2007 | 11:58 AM
Zack1978's Avatar
Zack1978
So are you say that if I buy a new 2007 Ram 2500 4x4 with the Hemi, I should not run 87?
Zack
Old Jul 10, 2007 | 12:25 PM
bdhuntr's Avatar
bdhuntr
You should fuel up with the octane rating the manufacturer suggests, unless (as previously mentioned by many) you have installed performance mods that mandate a higher octane fuel.
Octane ratings are a measure of the fuel's anti-knock quality and not its "power", although using the correct grade of fuel can increase an engine's power if it burns that fuel completely rather than pre-detonating it or wasting it unburned out the tailpipe.
Old Jul 10, 2007 | 12:31 PM
Zack1978's Avatar
Zack1978
ORIGINAL: bdhuntr
Well what does Dodge recc for an 07 2500 Hemi?
Zack
Old Jul 10, 2007 | 01:39 PM
FFMedic1479's Avatar
FFMedic1479
You should just check your owners manual... it will be right in there. I doubt much has changed, but Icould be wrong, but it should be 89. Before my tuner I used 87 without a problem, but after the SC (like I said earlier in this thread) I have been running 91 or 93 (whatever is available) and have gotten more power and more miles per tank.
Old Jul 10, 2007 | 01:50 PM
bdhuntr's Avatar
bdhuntr
ORIGINAL: Zack1978
ORIGINAL: bdhuntr
Zack
No offense, but it's just as easy for you to search forthat requirement as it is for me.
Regardless, that engine requires 89 octane gasoline.
Old Jul 10, 2007 | 02:50 PM
Zack1978's Avatar
Zack1978
ORIGINAL: bdhuntr
ORIGINAL: Zack1978
ORIGINAL: bdhuntr
Zack
Well considering the fact that I don't own own one as of yet, I can't simply "look it up"
Zack
