Fuel Octane?
Yes. Especially if you have certain mods under the hood or a tuner. The manual says that you should run 89 but with a stock setup you can run 87 as long as you don't beat the heck out the engine. Higher octane just burns cleaner and faster thus reducing the chance of knock and tapping. If you are stock run the 89 and you will not have any problems, if you want to run premium, go ahead. You figure it is only about a $7.00 difference compared to the lower grade and it will help out with MPG a little (especially if you have the mods for it)..
ORIGINAL: MexiRam
Any differnence between 89 and 92?
I run 89, well i used to, my tuner came today so i will be switching up to 91
Trending Topics
ORIGINAL: L and R Two
The higher the octane, the SLOWER the fuel burns, reducing preignition on hot pistons and cylinder metal.
That's why 87 octane pings like a biotch in high compression engines, (compression causes heat: IE Diesels) because it has a higher/faster burn rate, and a lower flash point.
To boot, running high octane fuel in a car NOT designed to run it is a waste, and due to a slower burn rate, can lead to piston/valve deposits due to causing an "over rich" condition.
I ran the 91 octane program with a tank of 87 octane fuel and couldn't pull out from a dead stop without the engine pinging. With the 91-93 octane in my truck, it runs a ton better.
