Superchips is on!!!
ORIGINAL: Pappy_FB
No idea about the Turn signals, thats a new one on me.
Did you get the most current update downloadedin the tuner?
Did you change any other settings? Speed or Rev limiters?
Check yer stock Tire Size (in the Tuner) I bet it says 31.25 & you prolly have 33s
What did you set yer shift points at?
ORIGINAL: Kane
filled er up with premium and put the performance tune in. took a ride and Im not impressed! I dont see any $450 value here.
and whats with the turn signals being slowed to almost a creep.
I justdownloaded about 3 hours ago so I would assume I got the newest updates.
I left the top speed limiter alone.
Engine Rev and shift points cannot be adjusted for 2007 models. Says right on the front page of the owners manual. "These options are not availible for 2007 vehicles"
I went in and looked when programming and sure enough. I couldnt make changes.
Tires are 31.50. I measured
I'm impressed with my flashpaq however I am still having a side effect that has pissed me off. I had isolated it to the remote starter but after 4 days without using a remote starter nor having any problems I tried to start it and it didn't work. I used the remote starter to start it and it started no problem. I shut it off and it didn't start again. I used the remote starter and went home. I left it for the night and the next morning it started like there was nothing wrong at all. Now I am on my 2nd or 3rd flawless day. I will look into troubleshooting it on Sunday.
Kane,
Sorry about the Flashpaq and lack there of options for the 07.
There are two different downloads the application itself and then run the app and download the update into the tuner.
As for measuring your tires try this link
http://www.dakota-truck.net/TIRECALC/tirecalc.html
Just plug in yer tire info. At first I thought me trusty tape measure was correct too.
