no reverse
Old Jun 19, 2007 | 08:14 PM
mudkicker's Avatar
mudkicker
Default no reverse
ive got a 2002 1500 5.9l i did a little burn out in reverse, just a quick stomp, and now i have no reverse. can you help me out?
Old Jun 19, 2007 | 08:44 PM
Max00racer's Avatar
Max00racer
Default RE: no reverse
new tranny...good luck with that. I mean other than that try flashing the computer.
Old Jun 19, 2007 | 09:20 PM
mudkicker's Avatar
mudkicker
how can i flash the computer
Old Jun 19, 2007 | 11:59 PM
HuntinHanson's Avatar
HuntinHanson
wow, sounds like that quick lil burnout cost you a couple grand...
Old Jun 20, 2007 | 12:07 AM
FFMedic1479's Avatar
FFMedic1479
Dude... no good... absolutly no good.
As for reflashing you computer... do a PCM reset... take the fuse out of the fuse box marked for the pcm, turn your key a couple times (don't turn it over, just to the power on position) the truck will ding a couple times, put the fuse back in. I don't know if there is some kind of tranny protection built in that this will reset, it is worth a try. Other then that you are SOL.
Old Jun 20, 2007 | 01:26 AM
Pappy_FB's Avatar
Pappy_FB
Sorry about yer Tranny bro. I hope its a cable or linkage dropped/broke off.
Until then always park nose out.
Old Jun 20, 2007 | 01:31 AM
NJMandCEM's Avatar
NJMandCEM
When i flash my PCM... Pull the fuse... then hold the key to start until it dings a couple times... Other then Good luck....
Old Jun 20, 2007 | 01:42 AM
FFMedic1479
Were you rolling forward or in drive when you threw it into reverse?
