Superchips new feature coming soon
Old Jun 30, 2007 | 08:33 PM
  #21
go49ers's Avatar
go49ers
Default RE: Superchips new feature coming soon
Maybe I am missing something which is entirely possible I have a 2006 and I can not adjust the shift parameters. I have the ability to adjust the Rev limiter, Tire size and top speed. These are all under the options section. Where is the shift option for those of you who can adjust it. Thanks in advance
Old Jun 30, 2007 | 10:09 PM
  #22
Pappy_FB's Avatar
Pappy_FB
I can't remember exactly. I rekon I'll go hook her up and check for yas.
Old Jun 30, 2007 | 10:21 PM
  #23
Pappy_FB's Avatar
Pappy_FB
Ok just checked they are under Options
Power Level ( I am set at 91 Performance Tune)
Options
WOT=Wide Open Throttle
I have mine set to
1-2 to 6000
2-3 to 5950
Old Jul 1, 2007 | 02:28 PM
  #24
go49ers's Avatar
go49ers
Pappy Thanks for checking. Isn't that really considered a Rev Limit and not a shift point since you cant set it below 5800? In other words if I wanted my truck to shift from 2-3 at 3500 RPM's I couldn't set that. See my thought process here?
Thanks
Matt
Old Jul 1, 2007 | 03:27 PM
  #25
Pappy_FB's Avatar
Pappy_FB
Ahh go49ers,
The Flashpaq Shift Points that you can adjust are NOT your normal driving shift points. They apply ONLY to Wide Open Throttle (WOT) shift points
Under normal driving your truck will shift as it always has.
Here is how it works
The Rev Limiter is for your Maximum RPM (Different from but related to Shift Points)
The Shift Points you adjust with the Flashpaq - ONLY affect WOT shifting and must be of a lesser value than Max RPM setting.
So if you leave the Rev Limiter at the Stock Setting then by default the shift points would prolly be stock also, and possibly not show up I rekon. I could be wrong.
Anywho to get my WOT 1-2 shift to 6000 I had to set my Max RPM to 6050 or 6100 (Me thinks)
Old Jul 1, 2007 | 04:01 PM
  #26
go49ers's Avatar
go49ers
Ahhhhh thank you my fellow floridian...... grasshopper much wiser now.
Old Jul 1, 2007 | 04:22 PM
  #27
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
I'd would like to see them make the shift points adjustable in the 2007 version. It seems since I installed my superchip I am not able to shift into OD until I hit 70mph and for fuel savings I would rather it automatically shift into OD about 60 or 65.
Old Jan 24, 2008 | 08:59 AM
  #28
2005cobrakiller's Avatar
2005cobrakiller
im young and I don't hate..... Prolly cause My HEMI lights fires under peoples asses..... LOL.....I have found more useful information off of these forums then I ever have by taking **** apart..... This forum is like crack.....or as dave chapelle would say...... Red *****...Liquid crack in a can!!!!!!!!
