code p2106 /p2175 question
Old Jul 7, 2007 | 11:56 AM
zapper's Avatar
zapper
Default code p2106 /p2175 question
i did theDIY turn key off and on test and came up with these 2 codes can not find them on the DIY page any helpers engine light on
Old Jul 7, 2007 | 12:26 PM
Duso02's Avatar
Duso02
Default RE: code p2106 /p2175 question
P2175 Throttle Actuator Ctrl Sys-Low Airflow Detected
P2106 Throttle Actuator Ctrl Sys-Forced Limited Power
Old Jul 8, 2007 | 05:19 PM
zapper's Avatar
zapper
thanks can you give me any idea on what to do?
Old Jul 8, 2007 | 07:59 PM
chadmech28's Avatar
chadmech28
The first code is related to lake of air flow check the air filter and also clean the ETC this may trigger the second code due to dirt build up. If this doesn't fix the problem you wil have to replace the ETC>
Old Jul 10, 2007 | 09:26 AM
zapper's Avatar
zapper
Whats a ETC and where is it located on the hemi 2003
Old Jul 10, 2007 | 11:12 PM
chadmech28's Avatar
chadmech28
The ETC is the Eletronic thottle control it's the throttle body. It is right on top of the intake. More than likely you will have to replace it>
Old Jul 11, 2007 | 03:14 PM
Duso02's Avatar
Duso02
ORIGINAL: chadmech28
Chadmech-The ETC is actually located under the fuse box. The "go" pedal is connected by cable to the ETC and then the ETC sends a signal to the TB to open or close the throttle thru the wiring harness, hence the term "drive by wire"
Old Jul 11, 2007 | 08:42 PM
chadmech28's Avatar
chadmech28
Sorry my bad, eletronic throttle body I meant. The sensor on the pedal is called the (APPS) accelorator positon sensor which sends to the throttle body. The throttle body is the problem in this case.
Thanks for the reply
Old Jul 12, 2007 | 12:20 PM
Duso02's Avatar
Duso02
Actually there is no sensor on the pedal. Like I said, the pedal is connected by a cable just like any go pedal. Thecable goes to the APPS whichis under the battery tray. The APPS is just a linear potentiometer (a variable resistor). It gives the PCM the signal on where the pedal is at so the pcm, thru the etc can send a signal to the throttle body. For troubleshooting your gripe,make surethe connectors on the TB and the APPS are tight. Check on how dirty your TB is and clean it if required. Use brake-cleaner only, don't use TB/Carb cleaner. Reset PCM and see how she goes.
Old Dec 27, 2010 | 12:59 AM
ahicksof4's Avatar
ahicksof4
Default codes p2175 and p2106
Hello everyone I"m new here to the Forum. though I have a couple of questions. I went and picked my daughter up in MS last night and when I got back in Nashville my engine light came on and the red lightning bolt flashed. I pulled over on the side of the road and notice that my 2003 Dodge 1500 was idling roughly. It has never done this until the lights came on last night. I continued on to the house and noticed it didn't have much power. Could some one please tell me what the problem might be and how I may fix it. I have only had this truck for 3 years. I did the code check and it gave me p2175 and p2106. Please help!!! Tyvm...Angie
