Infinity speaker upgrade ???
Old Jul 10, 2007 | 02:10 AM
ThaChad's Avatar
ThaChad
Default RE: Infinity speaker upgrade ???
I've used Infinity Kappa Speakers in my cars and Love them! You can buy the Kappa's online for what the lower end Referance model's cost at the local Retail store.
My question is... If you install an Infinity Kappa Speaker as a direct replacement for the stock speakers in the doors, Shouldn't you have no problems running them on the factory amp? Any aftermarket speaker should be far more efficient than the stock speakers, and thus would not only sound better, but shouldn't have a problem running on the factory amp.
I assume the factory Infinity system is just speakers in the doors and seperate tweeters in the dash? (My truck has the factory Infinity system, I just haven't done much research about them), Instead of a 2-way or 3-way speaker in the door? So basically a component system?
-TheChad
Old Jul 10, 2007 | 11:20 AM
casper3380's Avatar
casper3380
The only issue with the new kappa series, reference included, is they are 2 ohm vs the standard 4 ohm. This is to draw more power out of your amp. If you intend on running them off the original deck, this may pose a problem that the deck isnt designed to push these impedences. Otherwise here are some infinity's that will fit.
Kappa 693.7i 6x9 3-way speakers for the front doors
the only kappas rated for the back doors are the components (per crutchfield) kappa 60.7cs
It lists a dash location: kappa 32.7cf
hope that helps.
casper
Old Jul 10, 2007 | 01:39 PM
squirtbottle09's Avatar
squirtbottle09
If I am not mistaking the amp for the stock speakers is located on the back of the speaker its self. There are little amps built in I believe.
Old Jul 10, 2007 | 09:08 PM
Brawler's Avatar
Brawler
Found these and was curious if anyone has experience with them.
http://www.crutchfield.com/S-ctzTRiQ...B525&wm=cl
http://www.crutchfield.com/S-AlvwLNH...amp;i=107DB690
Old Jul 10, 2007 | 10:37 PM
TReX5.7's Avatar
TReX5.7
ORIGINAL: Brawler
I just got the same polks in my rear doors only their 6.5's. I love them, there's no comparison from stock.
Old Jul 11, 2007 | 12:31 AM
FFMedic1479's Avatar
FFMedic1479
ORIGINAL: squirtbottle09
You need to upgrade the speaker wire if you have a 4 channel amp. Go as big as possible. Take a look at my thread, labled Quad Cab Speaker System. They gave me a bunch of tips and stuff on what to do in my sons quad cab.
There is an easy way if you want to do baby steps when it comes to wiring... if you don't want to put components in or you are running a mild upgrade of speaker or just boosting the power to stock doors, you COULD hook in the wires coming from your amp into the stock wiring for the corresponding speakers behind the H/U. As long as you don't have a wicked powerful amp behind it, you should be ok. This will keep you from having to run wires to the speakers themselves. And, generally, bigger is better (with just about anything... that's why we all have big trucks, right?)
Old Jul 11, 2007 | 01:04 AM
xtothezxzibit's Avatar
xtothezxzibit
Old Jul 11, 2007 | 02:15 AM
squirtbottle09
That was one succesfull post above me. He is a serious newb when he cant even figure how to type, lol.
Old Jul 11, 2007 | 11:28 AM
FFMedic1479
Is that supposed to be like Pimp my Ride? Xzibit?
