Is she losing her mind?
Old Jul 18, 2007 | 06:16 PM
92DevilDog's Avatar
92DevilDog
Default Is she losing her mind?
I'm looking for some help on my 2002Black 1500 Quad 4x4 SLT. I think she's losing her mind.
My truck has 47000 miles on it and it has now started doing several odd things all at once.
1 - The ABS and Brake lights turn on after I hit about 20 mph. The brakes still feel fine, there is no pulsing when braking.
2 - The speedometer stays on 0 until it hits about 20 mph and then bounces all over the place.
3 - The gas milage sux (I know but its worse than normal, like when I'm coasting I get about 5 mpg).
A couple notes, these may or may not be associated:
4 - Before it started I had recentlychanged the front brakes
5 - About the same time it started we noticed that the exhaust had rusted through soI just had it replaced.
Any help would be appreciated
Thanks!
Old Jul 18, 2007 | 06:45 PM
casper3380's Avatar
casper3380
Default RE: Is she losing her mind?
items 4 and 5 wouldnt have anything to do with it. My question is does it have a control module. I had a dodge caravan with a control module issue that did similar things as you are reporting. I would go to a dealer and ask if it has a control module, could be the answer, or atleast a possibility. hope that helps some.
casper
Old Jul 18, 2007 | 09:14 PM
squirtbottle09's Avatar
squirtbottle09
It is possesed. Blow it up, NOW!
Old Jul 18, 2007 | 09:19 PM
Hemichief's Avatar
Hemichief
You changed the brakes... did you bleed your lines? have you checked your brake fluid? that may be part of the reason for your ABS light on. The fuel could be a myriad of things, specially if you changed the exhaust system. You need to make sure that everything was put where it belongs and everything was connected correctly. Are you throwing any codes?
BTW - Semper Fi Devildog... Thanks for your service...
Old Jul 19, 2007 | 09:44 AM
92DevilDog's Avatar
92DevilDog
Thanks for the help guys! Semper Fi!!!
One other thing that I remembered after Imade the post...
About 3 years ago I had to get the ABS Wheel Speed sensor replaced in the rear diff. Now that I think of it, there are alot of the same characteristics. Could be the same thing again, and there is also another ABS wheel speed sensor in the front as well.
