34 Gallon tank REALLY 34 Gallons?
Old Jul 20, 2007 | 08:19 PM
WhiteBerry's Avatar
WhiteBerry
Default 34 Gallon tank REALLY 34 Gallons?
ok, so my truck has the upgrade to 34 gallons... i watch my mpg & DTE (distance to empty) like a hawk... under about 40 DTE it switches to "LO FUEL". so i figure i drive another 20 or so miles, even with worst case, now i should get down to about 1-2 gallons, therefore fill up with 32-33 gallons... $85 later, i only put in 29! what gives?!?!? is the computer estimate THAT far off from actual?
Old Jul 20, 2007 | 08:24 PM
07 Ram TRX4's Avatar
07 Ram TRX4
Default RE: 34 Gallon tank REALLY 34 Gallons?
The last i knew... When i had me 05... before the lo-fuel.... When it said 0... I belive i still have 5-15 percent of a tank.. can't remember... But the senser does'nt go down the the exact amount of fuel... More a get your *** to the nearest gas station... If you did'nt know that... then you'd flip out being 5 miles from the nearest station when the thing shows 0... But because of the lo-fuel warning... hard to say where you are.... Might be the same way.. But i doni't know... just know that when the light comes on... i need me some petro.... Hope this helps....
Old Jul 20, 2007 | 10:27 PM
squirtbottle09's Avatar
squirtbottle09
Some call the computer the lie-o-meter...
Old Jul 20, 2007 | 10:33 PM
JimmyDiablo's Avatar
JimmyDiablo
1/2 tank then fill it. not only will it keep dirt from being introduced to the engine, but will mentally seem like you are spending less.
Old Jul 20, 2007 | 11:20 PM
dodgerules86's Avatar
dodgerules86
ORIGINAL: jimmydaleo
that, and its better on the pump, which is cooled by the fuel.
Old Jul 21, 2007 | 12:27 AM
FFMedic1479's Avatar
FFMedic1479
Isn't the fuel pickup in a fixed location inside the tank, making whatever sludge that is on the bottom get sucked in anyways? It doesn't move with the level of the fuel.
Old Jul 21, 2007 | 02:15 AM
Powerubi Wacon's Avatar
Powerubi Wacon
I've run my tank down, a couple of times, to where I pump in around 31-32 gallons before. I average about 28-30 gallons on a fill up. I am not afraid to run my tank low.
Old Jul 21, 2007 | 02:23 AM
Captain Squalus's Avatar
Captain Squalus
I refuel every 2,500 miles wether I need fuel or not.
Old Jul 21, 2007 | 11:14 AM
slapshot12's Avatar
slapshot12
Many different vehicles I have seen have a little margin of error towards reading lower than they actually are. They may read "E", but still have a few gallons left in them. I bet if you ran it truly engine stalled empty, it would take real close to 34. I have the 34 gallon tank also and it usually takes around 16 or 17 gallons to fill it from half a tank.
Old Jul 21, 2007 | 01:39 PM
vwomein's Avatar
vwomein
ORIGINAL: Captain Squalus
Sweet!!!! I wish I only had to refuel every 2,500 miles
