3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
i used to run a flowmaster 30 series on my geo. i loved it but it just wasnt loud enough. i then bought a 10 series race muffler and it still didnt make it scream like i was wantin it to. so i finally welded on my very own homemade tincan muffler and it makes my geo sound just like a 2 stroke dirtbike!!!!!
Having the Hemi, depending on your setup, will need the 50 series. This is the only one that Flowmaster recommends running with a single in dual out setup. Anything else and you will need to run true duals with 2 mufflers on the flowmaster setup to get the flow needed. As far as the 3030, I don't know much about that so I will have to let others chime in on this.
Thanks for the help. So if you want to keep the single exit in the stock location you need to stay with the 50 series??? I am guessing the is just for the flow master series of mufflers. I did not know that chambered mufflers made that big of a difference. I listened to the sound clip of the 3030 online and it sounds good. Just wondering about when the mds kicks in???
