Changing Front Hub Bearing
Old Aug 3, 2007 | 07:21 PM
sobrien's Avatar
sobrien
Default Changing Front Hub Bearing
I am trying to change the front hub bearing on an 05 3500 4x4.The manual I have tells me to remove the rotor (naturally) however the section on removing the rotor refers me to the section on removing the hub bearing. Now I feel like a piston in a bad engine. So a I decided to go off of instinct and remove the rotor from the axle, however it will not come off of the shaft [:@]. Any Ideas
Thanks in advance.
Frustrated owner
Old Aug 3, 2007 | 07:52 PM
HuntinHanson's Avatar
HuntinHanson
Default RE: Changing Front Hub Bearing
what manual are you trying to use? try going into this one and following their method
http://www.hemitruckclub.com/
scroll down and look on the left side...
Old Aug 3, 2007 | 09:52 PM
nastyram's Avatar
nastyram
if it is the same as a 1500,just did mine on monday,to remove the rotor remove the calitper and the cailiper bracket an slid the rotor off
Old Aug 3, 2007 | 09:59 PM
casper3380's Avatar
casper3380
could be a clip holding it on, should be easier to come at it from the outside. Every hub ive taken off, ive come from the outside, not the axle
