CODE P 0442
Old Aug 6, 2007 | 08:10 AM
Jasonpearee's Avatar
Jasonpearee
Default CODE P 0442
Does anyone here know what this code means...?
Old Aug 6, 2007 | 07:06 PM
chadmech28's Avatar
chadmech28
Default RE: CODE P 0442
evap leak smal is what this means
Old Aug 6, 2007 | 07:17 PM
CarGuyOhio's Avatar
CarGuyOhio
This is a VERY common code. If you did a search on it you would find it is a issue with your gas cap or the rubber hose from the tank to the fill hole.
Old Aug 6, 2007 | 07:21 PM
nastyram's Avatar
nastyram
had the same code a few weeks ago,turn out to be the gas cap
Old Aug 7, 2007 | 10:40 AM
Jasonpearee
thanx for all of you guys help, I'll check out the fuel cap... And if it is the cap will that shut the engine check light off or do I have to reset it somehow...? If so how do I do this...? Thanx again....
Old Aug 7, 2007 | 10:42 AM
CarGuyOhio's Avatar
CarGuyOhio
If you fix it the light should turn off within 100 miles, but you could always pull the batter cable, wait a minute and put it back on.
Old Aug 7, 2007 | 10:44 AM
Jasonpearee
cool thanx again...
