2006 Ram 1500 standard radio wiring diagram
Old Aug 7, 2007 | 04:24 PM
eltupac's Avatar
eltupac
Default RE: 2006 Ram 1500 standard radio wiring diagram
Ok. If you see the link I sent you, you can see the image has codes to the wires.
If you look at the right rear speaker (+), its coming from Connector 1(C1), from pin 21 (21). You keep looking up the line and it says Dark Green/ Light Green(DG/LG LG is the strip while DG is most of the wire, this sequence applies to all wires) on wire gauge 18 (18) to connector C308(at the door jamb) to the positive of speaker.
Now to connect this to an RCA to your amp, get an RCA from radio shack that has wires loose on one end. Connect the + to the positive from the radio, - to the negative from the radio.
You probably knew that, but just in case anyway.
Old Aug 7, 2007 | 05:52 PM
kenihemi's Avatar
kenihemi
Also check out 8w-80-103
Old Aug 7, 2007 | 10:24 PM
therockdog's Avatar
therockdog
ORIGINAL: eltupac
I Feel like the biggest tard!! Me being a Network Specialist shouldknow how to read a diagram.After i got home and sat down and really looked at it i found out that it was in there. Thanks for ya'll's help. i will let ya know when i get it done.
Old Aug 7, 2007 | 10:39 PM
Parts/Service's Avatar
Parts/Service
RADIO C1 - BLACK 22 WAY
CAV
CIRCUIT
FUNCTION
1
A114 18GY/RD
FUSED B(+)
2
3
4
X716 20GY/TN (HANDS FREE)
LEFT AUDIO OUTPUT
5
D55 20WT/OR
CAN B BUS (+)
6
D54 20WT
CAN B BUS (-)
7
X154 18GY/YL (BASE)
RIGHT FRONT DOOR SPEAKER (+)
8
X156 18GY/LB (BASE)
RIGHT FRONT DOOR SPEAKER (-)
9
X155 18DG/LB (BASE)
LEFT FRONT DOOR SPEAKER (-)
10
X153 18DG/YL (BASE)
LEFT FRONT DOOR SPEAKER (+)
11
Z514 18BK/LG
GROUND
12
A114 18GY/RD
FUSED B(+)
13
14
15
16
X776 20TN/GY
RIGHT AUDIO OUTPUT
17
X795 20DG
COMMON AUDIO OUTPUT
18
X205 18GY/LG (BASE)
LEFT REAR SPEAKER (+)
18
X51 20DG/DB (PREMIUM)
19
X295 18GY/DG (BASE)
LEFT REAR SPEAKER (-)
19
X57 20DG/OR (PREMIUM)
20
X296 18DG/GY (BASE)
RIGHT REAR SPEAKER (-)
20
X58 20GY/OR (PREMIUM)
21
X206 18DG/LG (BASE)
RIGHT REAR SPEAKER (+)
21
X52 20GY/DB (PREMIUM)
22
Z515 18BK
GROUND
RADIO C2 - GRAY 10 WAY
CAV
CIRCUIT
FUNCTION
1
X16 20DG/YL
AUDIO SIGNAL RIGHT (+)
2
X917 20DG
AUDIO SIGNAL COMMON
3
4
X510 18DG/LB
VDO-AUX AUDIO RIGHT
5
X916 20GY/OR
SDARS AUDIO RETURN
6
X17 20DG/OR
AUDIO SIGNAL LEFT (+)
7
X910 18GY/DG
AUX AUDIO RETURN
8
X511 18GY/LG
VDO-AUX AUDIO LEFT
9
X521 18GY/LB
VDO-AUX AUDIO LEFT 2
10
X522 18GY/DB
VDO-AUX AUDIO RIGHT 2
AMPLIFIER-RADIO C1 (PREMIUM) - WHITE 20 WAY
CAV
CIRCUIT
FUNCTION
1
X209 18GY/OR
LEFT INSTRUMENT PANEL SPEAKER (+)
2
X208 18GY/DG
RIGHT INSTRUMENT PANEL SPEAKER (+)
3
X200 18GY/BR
CENTER INSTRUMENT PANEL SPEAKER (+)
4
A116 16YL/RD
FUSED B(+)
5
6
D55 20WT/OR
CAN B BUS (+)
7
X51 20DG/DB
8
X52 20GY/DB
9
Z907 18BK
GROUND
10
X299 18GY/YL
LEFT INSTRUMENT PANEL SPEAKER (-)
11
X298 18GY/LG
RIGHT INSTRUMENT PANEL SPEAKER (-)
12
X290 18GY/OR
CENTER INSTRUMENT PANEL SPEAKER (-)
13
A116 16YL/RD
FUSED B(+)
14
15
16
17
D54 20WT
CAN B BUS (-)
18
X57 20DG/OR
19
X58 20GY/OR
20
Z513 18BK
GROUND
AMPLIFIER-RADIO C2 (PREMIUM) - WHITE 14 WAY
CAV
CIRCUIT
FUNCTION
1
X153 18DG/YL
2
X154 18GY/YL
3
X205 18GY/LG
4
X206 18DG/LG
5
X30 16DG/TN (SRT)
SUBWOOFER SIGNAL (+)
6
7
X155 18DG/LB
8
X156 18GY/LB
9
X295 18GY/DG
10
11
12
X296 18DG/GY
13
X31 16GY/TN (SRT)
SUBWOOFER SIGNAL (-)
14
Old Aug 7, 2007 | 11:47 PM
therockdog's Avatar
therockdog
thanks the funny thing is i have two plugs both are gray one is a 12 pin and the other is a 20 pin connector.
Old Aug 8, 2007 | 08:18 AM
eltupac's Avatar
eltupac
Well, if you are Novell Certified that explains it. just kidding, just kidding. I dont have a single one. I would love to be Cisco, MC, or any.
Old Aug 8, 2007 | 09:39 AM
therockdog's Avatar
therockdog
Lucky me it isn't Novell!!!! yeah i would like the MCSE. Right now i am Dell, fiber optic, Bicsi,certified. My back ground is Voice and data cabling infrastructure. But it's all good in the hood! i will let you know if i get the amp up in the truck. Peace!
