3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I just replace the brake light bulb on the the passeneger side cause it blew an now I keep blowing the fuse for it an the bulbs are good anyone with an idea why?
no, mine did the same after i got my instrument panel replaced, i tihnk the wires are screwed up in mine ans the passenger side won't even come on.. ive been driving without a passenger sidebrake light for 6 months now .. have yet to know why, i replace the bulbs but it still won't come on
Are you sure the bulb was inserted the riight way? i have'nt seen the bulb itself... but i know the older ones were meant one way... and if you were'nt payin attentino you could put it in backwards....other then that... could'nt imagine what your problem is....
Im pretty sure the it dont matter which way the bulb is with these one but im kinda thinking that the plug it self could be bad since i tryed the driver side unit on the passenger an still the same result.
