4X2 TO 4X4 CONVERSION
Old Sep 10, 2012 | 11:08 AM
08HEMI1500's Avatar
08HEMI1500
This was done successfully if you search for " SAS". He had to use a GM front axle though because if you're going to convert your truck you might as well go SFA and not IFS since it's less complicated and you can't use a dodge front axle because the Dana 44s are too weak for the 3rd gen and I don't think a 2500/3500 one is compatible
Old Jun 10, 2018 | 12:51 PM
Jon swim's Avatar
Jon swim
Originally Posted by HemiLonestar
5 YEAR OLD THREAD RESURRECTION!!
02-05 would be compatible.
4.7 will bolt to same tranny? And does the suspension and everything bolt right up?
Old Jun 10, 2018 | 07:50 PM
No, the suspension does not bolt right up. Cutting and welding will be required. Cheaper/easier to just buy a 4x4 truck, and sell your 2wd.
Old Jun 11, 2018 | 09:56 AM
HemiLonestar's Avatar
HemiLonestar
02-05 2wd uses front coil springs with shocks, the 02-05 4wd uses torsion bars and shocks. Good luck with that lol.
