Engine stalling
Old Aug 25, 2007 | 10:58 AM
pinoydodge's Avatar
pinoydodge
Default Engine stalling
I have a 2005 Ram 1500 with the 4.7 motor that just stalls or die for no apparent reason. Sometimes while stopped with my foot on the brakes, the car RPM will surge up and down. Check enigine light is NOT on. Not a lot fun when the engine dies while turning !!! Need some help.
Thanks!
Old Aug 25, 2007 | 11:58 AM
07 Ram TRX4's Avatar
07 Ram TRX4
Default RE: Engine stalling
Could be a number of things....EGR valve...PCV Valve...... Bad sensor......
Old Aug 25, 2007 | 02:02 PM
Brother Rob's Avatar
Brother Rob
Retired Moderator
Posted the same problem, earlier this month.
https://dodgeforum.com/m_912308/tm.htm
Old Aug 27, 2007 | 10:51 PM
pinoydodge's Avatar
pinoydodge
Thanks for all the info..
Old Aug 28, 2007 | 02:09 AM
287cc's Avatar
287cc
Try cleaning your throttle body and tps sensor. It could also be your idle air control (IAC)motor going. My fix was when the dealer had to reflash my pcm with an updated one.
Old Aug 28, 2007 | 02:56 AM
chefred112's Avatar
chefred112
....hey pare...kumusta...welcome to Dodgeforum...the stalling issue has shown up on my hemi as well...every so often it does it on me when I'm stopped...I'm gonna try and clean my tb as well...
Old Aug 28, 2007 | 09:15 AM
HammerZ71's Avatar
HammerZ71
Do the following:
1) Have dealer re-flash PCM - it's a TSB so should be free.
if not fixed then...
2) Replace EGR (most often this is the fix)
then...
3) Clean Throttle Body.
in that order... 99.9% of the time, one of these will make the problem go bye-bye.
Old Aug 28, 2007 | 10:50 AM
moneymanted's Avatar
moneymanted
I had the same problem. My check engine light came on and off with the problem. The dealership replaced the EGR valve, and that solved the problem.
Old Aug 29, 2007 | 09:50 AM
pinoydodge's Avatar
pinoydodge
ORIGINAL: chefred112
Mabuti naman! Salamat!
Old Aug 29, 2007 | 10:01 AM
pinoydodge's Avatar
pinoydodge
ORIGINAL: HammerZ71
Do the following:
then...
Thanks again for the help. Where exactly is the EGR valve located?
