How deep is too deep in water?
I am heading out on a kayaking vacation and have found out that I will need to perform some water crossings. Does anyone know what would be a safe water depth for a stock 1500, 4x4, 1500 QC?
The water would be tidal pools and sandy beaches not streams so I wouldn't have to worry about hydraulics forcing the water up into the engine compartment unless i was driving too fast. I have seen a lot of , cough cough - subaroo's do it and get stuck.
I used to have a Jeep and went through whatever I wanted. Got stuck a couple of times but do not want to on vacation with the Mrs. and a newish truck. Nor hold up the rest of the group.
I don't know what is the real safe height, but I have ran my 4x2 megacab stock through about 16 inches of water driving pretty slow as not to get water up in the engine compartment.
Make sure you take Plan B with you if going seriously off road. If going single vehicle you definitely need to get yourself a winch, if going with multiple trucks then I rec about 40ft of heavy duty tow straps between you.
Trending Topics
My rule of thumb has always been never to go through water that was so deep that it got to my fan, or deeper then my starter. "SPLASHING" water is one thing, but when you submerge your truck in water deep enough to get to the fan, your starter is under water, and fills with water. It also means that your serpentine belt is running in water and the fan will push a lot of water on the engine, near the air intake, until it stops (fan clutch) due to drag.
If you drive SLOWLY though water up to midwheel,you should be fine, as both your axles have vents that run higher then that, and that should be just at or below bumper level....
Just use common sense..... ENjoy your vacation.
if the exhaust submerges, throttle up. the pressure will keep the exhaust from comin out.
before crosssing, walk it if ya can. look from the shore. plot a safe lookin course. if ys hit and drop the front in a deep hole, youre f'd if noone else has a winch to yank ya out.
The ONLY part of the engine that needs to be above water is the air intake. The engine is mostly waterproof to protect against splashing from rain and such. Look at the H1 Hummerit has a snorkel that extends above the cab.... it can literally completely submerge its self as long as the snorkel is above water... the only worry you would have is if the cab is NOT water tight and it floods past the underside of the dash.... then your computer will short out..... Those are your 2 biggest limiting factors....
