07 Ram Front Drive Shaft Lubrication
Old Aug 27, 2007 | 12:58 PM
dodgeram350007's Avatar
dodgeram350007
Default 07 Ram Front Drive Shaft Lubrication
The front drive shaft on my 2007 Ram 3500 requires a lithium based lubricant, I have looked all over the drive shaft for a grease fitting and can’t find anything. Does the skid plate need to be removed for access? If anyone knows please enlighten me!
Thanks
Old Aug 27, 2007 | 11:40 PM
gooddoc's Avatar
gooddoc
Default RE: 07 Ram Front Drive Shaft Lubrication
It's a needlezerk grease fitting, that's why you're missing it. It sits flush and you need a special needle grease gun adaptor that gets inserted into for greasing. I assume you're looking for a standard zerk fitting sticking out. Look again with this in mind and I bet you'll find it.
Good luck.
Old Aug 28, 2007 | 08:58 AM
dodgeram350007
Thanks, found it no problem!
Old Aug 28, 2007 | 10:59 PM
gooddoc's Avatar
gooddoc
You're welcome.
Old Aug 29, 2007 | 02:20 AM
ThaChad's Avatar
ThaChad
Can you get to the fitting with out droping the drive shaft?
I took my '06 to the local Speed Lube, and the manage there said you can't get to the needle fitting with out dropping the drive shaft, which sounds kind of dumb to me, but 3 of the guys there said the same thing....
-ThaChad
Old Aug 29, 2007 | 09:27 AM
DCXgageman's Avatar
DCXgageman
Don't need to drop the 'shaft. Easiest way to find is get the left front tire in the air, crawl underneath to see the joint, then rotate the tire while looking for it. It's there, but can be hard the first time, have patience with it.
Old Aug 29, 2013 | 03:33 PM
happysahd's Avatar
happysahd
I realize this is an old topic, but I have spent the past hour looking around under there for the needle zerk fitting and I can't find anything that even looks like somewhere grease should go...please help.
Old Aug 29, 2013 | 05:12 PM
happysahd's Avatar
happysahd
Default Holy forehead smacking craziness!
I'd like to find the engineer that decided hiding a grease fitting inside there was a good idea and smack the crap out of him. Finally found the fitting and after stabbing myself suitably in the thumb with the darn needle fitting got it greased up good. I won't say just how many pumps I put into it, but lets just say it's probably never been greased...ever. Dealerships, Jiffy Lube, they all lie. Anyway these are the two pictures I took of it after I cleaned it off and before it got greased. Hopefully this helps somebody else in the future.
Attached Thumbnails  07 Ram Front Drive Shaft Lubrication-grease-fitting.jpg    07 Ram Front Drive Shaft Lubrication-grease-fitting-2.jpg
Old Aug 29, 2013 | 06:04 PM
Gone Fishin's Avatar
Gone Fishin
-ThaChad
They are just too f-ing lazy to do it. I've been doing mine for 182,000 miles and never pulled the drive line once, with the skid plate in place, it's not easy, but it isn't really hard either------5 minutes after you find it the first time---just get a hypodermic greasing needle, and a flashlight.
Old Aug 30, 2013 | 10:43 AM
happysahd's Avatar
happysahd
Default addendum...
...and avoid stabbing yourself
