P0236 Turbocharger Boost Sensor A Circuit Range/Performance
Old Aug 28, 2007 | 03:06 AM
bully's Avatar
bully
Default P0236 Turbocharger Boost Sensor A Circuit Range/Performance
Does anyone know what the problem associated with the code and it's description?
Keep on Rammin..........
Old Aug 28, 2007 | 03:53 AM
bully's Avatar
bully
Default RE: P0236 Turbocharger Boost Sensor A Circuit Range/Performance
The P0236 code came from reading DTC's from Bully Dog downloader. When I used the key feature on the truck I got P0234 TURBO BOOST LIMIT EXCEEDED. OOPS! Would that make it run rough and can I clear it somehow?
Thanks for any info you can provide....
Old Aug 28, 2007 | 10:07 AM
master tech's Avatar
master tech
Site Moderator & Tech
You may need a boost swtich. If you would like I could send you the diag sheet. Just send an email or pm. Leonard
