2005 RAM Installed K&N - 30 min later - Running bad ?
RE: 2005 RAM Installed K&N - 30 min later - Running bad ?
Thanks for the tips.
It was just the filter, not the kit. It was right out of the box, and it comes pre-oiled. I pulled it out right after the light came one, and am running with the stock filter so something happened.
I have a dealer down the street, and its under warranty - do they charge to check and reset the engine light? I would rather take it there if its gonna be something more then just a reset because now its running rough.
All clamps are tight, and nothing came lose when I changed the filters. Im carefull of that for sure. Goes to show that messing with factroy parts is never a good idea. I was going to get aftermarkt tail lights, but I did that on a SUV, and they both leaked and collected water.
ORIGINAL: njramguy
However if you want to get the code and try to figure it out on your own
https://dodgeforum.com/m_691136/tm.htm
To clear the code without a programmer just pull the battery cable for a minute.
holly crap, they should put that code check in the manual! Worked perfect on my 05. I gots me a bum EGR P0406 Exhaust Gas Recirculation Sensor A Circuit High
1) This should be covered under bumper to bumper warranty right?
2) Would this have anything to do with a K&N Air Filter being installed?
3) If this is the only problem, would a typical dodge dealer carry this sensor in stock?
Thanks again for all the help guys. Glad to be owning my first RAM and part of this board!
I used to have K&N air filters, for many years,on all of my cars. I always questioned the benefits of it because I could never really feel any difference in performance. What I did notice was the migration of oily dirt that was between the filter and carburetor/throttle body. I did not like seeing that.Last October I yankedALL of the K&Ns from my vehicles and tossed them in the trash.I came across some comparisons between a Wix air filter and a K&N and was shocked at what I saw. Not really, because of already mentioned oily dirt migration. I saw that althougha K&N does flow just a little more air than a Wix paper filter the K&N also lets a lot more dirt passed the filter. So it was bye-bye K&N for me!
I had a guy here cross check the code on a universal hand held reader, and it was the same #. But he erased it. Does it save somewhere so when the dealer checks it, they can still see what the code was?
*** Also saw 1 post on here where the EGR is not covered under warrany? Hope thats not true! Any mechanics that work at dealers know?
ORIGINAL: prerunner
So what is the sensor between the filter and the TB????? all the other vehicles i've had called it an MAF.
ORIGINAL: njramguy
A EGR is not to big a deal even if not covered under warranty. I think it is on the front left side of the intake, I would have to double check that though.
If the EGR is the reason for the rough running truck the air filter had 0 to do with it.
If you are interested in other DIY stuff there is a sticky message at the top of this forum.
ORIGINAL: njramguy
the dealer will charge you the 1 hr diagnostic fee to check the light and reset it....like 94rt said, just unhook the battery to reset the light
It was the EGR valve. It was 100% covered under warranty. I have some of the 3/36, then it was certified, then I have the 8/100 so between the 3. The dealer got the same code I did with the on off off the ign. 3 times...thanks guys!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
**** So from what was wrong, do you guys think that the K&N had nothing to do with this? Just ironic that it happened at the same time?
