Synthetic oil..???
Old Sep 11, 2007 | 06:57 PM
Silver Doug's Avatar
Silver Doug
Default Synthetic oil..???
Is Synthetic oil better..?? Why... and what improvements do you see...?? I understand you can go longer w/o an oil change..how long..?? do you also go longer on the grease jobs as well..??? can you also put synthetic In the transmission and rear end....If so why...???
Old Sep 11, 2007 | 06:59 PM
HuntinHanson's Avatar
HuntinHanson
Default RE: Synthetic oil..???
Yes it is better. Its keeps the seals in better shape, has less friction and makes it easier to start up in cold weather especially. You can put synthetic in both the tranny and rear end as well. Same reasons....
Old Sep 11, 2007 | 08:55 PM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
+1
Old Sep 11, 2007 | 09:46 PM
JimmyDiablo's Avatar
JimmyDiablo
Agreed, in fact our transmissions call for synthetic fluid ATF4
Old Sep 11, 2007 | 10:42 PM
hemiyellow's Avatar
hemiyellow
DC Insider
yep...synthetic all the way...put it in everything
Old Sep 12, 2007 | 09:47 AM
amarek's Avatar
amarek
My truck has 200 000km on it, Just got it off the father in law and was wondering if I should switch to synthetic, I was told before that the benefits are minimal when there is alot of mileage.I am hoping to keep the truck for a while (5 years)
Old Sep 12, 2007 | 09:57 AM
Pappy_FB's Avatar
Pappy_FB
To answer the how long question
Well you can't just throw synthetic in yer engine and call it good for 7000 miles
You need to, at a minimum change out the filter OR use a extended life filter.
Even tho I use a high end K&N filter, I still change out the oil and filter at 5000.
My 2 cents
Old Sep 12, 2007 | 09:59 AM
tdmopar59's Avatar
tdmopar59
wat kinda synthetic fluid do you reccomend for the rear and tranny?
Old Sep 12, 2007 | 11:54 AM
HuntinHanson
Im sure many people know this is coming..... amsoil!
Old Sep 12, 2007 | 12:54 PM
tdmopar59's Avatar
tdmopar59
amsoil for tranny? and dif? what about your engine im using mobil 1 right now but almost due for an oil change... do you think amsoil is a better choice... y?
