remote starter!!!
Old Sep 28, 2007 | 09:22 PM
  #41
Brother Rob's Avatar
Brother Rob
Retired Moderator
Default RE: remote starter!!!
ORIGINAL: moparmutt
I also want the remote start with alarm. I talked to a local place. He said he could install a Viper alarm/start for $499 or one with a pager for $650. Seamed kind of high to me.
He said he had a Hornet system that I could install for $300. It had 1 pager, 1 reg. button, remote start and alarm. The price is better, but I'm going to do some more checking.
I'm having a Viper, installed on Monday. $489 w/pager and remote start (500ft. range on pager). I'll let you know how it turns out. The next highest Viper was $599, installed. The only difference was more available channels and longer pager range (1 mile).
Old Oct 4, 2007 | 05:41 PM
  #42
Brother Rob
Retired Moderator
I was mistaken. It was a Python 881XP. I had them install the tilt sensor (extra $50), too, so no one can jack up the truck and swipe the wheels. Install went well. The remote start is nice. It has extra channels left, so I can add the defrost module, windows, etc... I might add window function, later. I live in So. Cal., so I don't really need defrost. The dealer told me the remote was good for 500ft, but the manual says it has a 1 mile range. BONUS!
Old Oct 4, 2007 | 08:17 PM
  #43
moparmutt's Avatar
moparmutt
Where did you get it?
Old Oct 5, 2007 | 07:27 AM
  #44
Brother Rob
Retired Moderator
I got it at a local shop (Stereo 1), but you can check outyour local dealer @
www.directed.com
Old Oct 5, 2007 | 08:36 AM
  #45
starhm's Avatar
starhm
If you are looking simple, Dodge sells remote starters with a factory harness. I got one for $249, three pieces (contol unit, the CPU for your vehicle, and thet-harness to plug into your ignition harness)and did the install myself. The remote is small and goes on the keychain, no lock wires to mess with. You have to run three wires out of the cab if I remember correctly. You will have to check for range. It is an eeay and relatively cheap alternative that is made for the truck.
