Truck will not start
Old Sep 25, 2007 | 07:48 AM
JRuffryders0930's Avatar
JRuffryders0930
Default Truck will not start
I hope somebody here can please help me. I am lost. I have a 2002 Dodge Ram 3500 with the 5.9l in it. The truck cranks but it will not start. I checked the fuel but no fuel comes of the shradder valve while cranking. i check to see if there is power to the pump and there is power to one wire. I also noticed that the fuel guage is not working. I changed the fuel pump a few months ago. So right there i was going to change the fuel pump again but i decided to check for spark. I have no spark. I checked to see if i had power at the coil but i have no power to the coil either. So i thought maybe the ignition switch. i change the switch and still no go. Can anybody please help me i would really appreciate it. Thank you
Joe
Old Sep 25, 2007 | 10:49 AM
07 Ram TRX4's Avatar
07 Ram TRX4
Default RE: Truck will not start
Do the basics.... Start pullin fuses.... check em.... move the relays around... look for broken wires around the engine make sure all the harnesses are together.... You could have pull sumtin doin your pump and it just finally wiggled loose....
Old Sep 25, 2007 | 03:27 PM
JRuffryders0930
Thanks for your response. I started to play around with the computer by hitting it and wiggling the connectors. Tried to start it and it started. Then i test drove it and while i was at a light it stalled on me. i got out and hit the pcm again and it started. I just got a price on the pcm and it costs over 500 dollars with a 125 dollar core. thanks again for your input.
Old Sep 25, 2007 | 05:47 PM
Gone Fishin's Avatar
Gone Fishin
Before you change the ECM, check all the connector plugs that plug into it, make sure you pull the neg battery cable BEFORE YOU PULL THOSE PLUGS. There have been some folks here that have reported corrosion on the terminals. Best bet, clean em good, then pack the connector box that is on the ECM with silicone grease, #2 lithium grease can be used, but silicone is much better, and it will seal out all the water that causes the corrosion. Also, check the wires as they enter the plug connector to make sure none are broken, pushed out, etc.
Old Sep 25, 2007 | 07:04 PM
a4twenty's Avatar
a4twenty
ORIGINAL: Gone Fishin
is that better than dielectric? ( or is it the same )
Old Sep 25, 2007 | 11:44 PM
07 Ram TRX4
Well I'm glad you got her runnin... But do what's said.. dissconnect and check all the wires... You'll feel like a real *** when they replace it and then afterwards tell ya all it was.... was a little corrosion in the harness... Never hurts to check anyways...
