Iridium spark plugs.
Old Sep 26, 2007 | 11:37 PM
marv02's Avatar
marv02
Default Iridium spark plugs.
Are Iridium Spark plugs worth the money or should I stay with platinum Plugs and why.
Old Sep 26, 2007 | 11:43 PM
HAWKDRIVER's Avatar
HAWKDRIVER
Default RE: Iridium spark plugs.
I'd stay away from platinum. It seems everyone here has either had problems or was told to stay away. Try iridium or standard. One guy was getting like 7-8mpg on platinums.
Old Sep 26, 2007 | 11:50 PM
HAWKDRIVER's Avatar
HAWKDRIVER
Sorry its late. I'm going to bed. I thought you were asking about Platinums. Rock on brother.
Old Sep 26, 2007 | 11:57 PM
marv02's Avatar
marv02
What kind of plugs come in our trucks I just when to the Dodge parts site and Dodge wants $2.99 per plug for OEM.
Old Sep 27, 2007 | 12:00 AM
HAWKDRIVER's Avatar
HAWKDRIVER
Not sure what brand but their just a standard style plug in the 4.7 notwithstanding the plug mounted coil.
Old Sep 27, 2007 | 12:08 AM
marv02's Avatar
marv02
I guess I need to startFinding out what type of Plugs our trucks came with Stock.
When I had My old Ford It came with Platinum plugs stock but some after market Platinum plugs did not work will I was useing Boush 4+ platinum they worked fine for me, or until it blew the plug out of the head Ha Ha thats anouther story.
Old Sep 27, 2007 | 12:18 AM
marv02's Avatar
marv02
Stock Plugs are calling out for Double Platinum Plugs ?.
Old Sep 27, 2007 | 12:31 AM
marv02's Avatar
marv02
Anouther Web Site Is telling me The Stock Plugs Are Iridium Who knows It time to go to bed I have to get early to go back to work Someone has to know but who ????.
Old Sep 27, 2007 | 12:56 AM
abarmby's Avatar
abarmby
Champion coppers are the stock plugs.
I run with the iridiums on my Hemi and they're great. 20,000 miles+
Not sure about the 4.7......?
Al.
Old Sep 27, 2007 | 07:38 AM
HankL's Avatar
HankL
Sparkplug designs with tiny & sharp center electrodes seem to be the trend of the future.
To keep the tiny electrode from melting they add the rare earth metal irridium to the alloy used. It is not pure irridium, and has platinum and other metals.
People who work in Chrysler's Dyno test room have reported that the 5.7 is within 5 degrees of 'best torque' ignition timing on 89 octane gasoline.
Using an irridium tipped sparkplug set at a wide 0.060 gap with both sparkplugs indexed so that the open gap is in the direction of the center of the cylinder and the ground post is over toward the cylinder wall is a mod worth investigating, along with a change to 93 octane gasoline for a margin of safety against detonation.
The sharp center tip, big gap and indexing
would probably increase
'fast burn'
enough to advance the 'real world' burn timing
from the factory 5 degrees past top dead center
to close to the 10-12 degrees past top dead center
where maximum torque is made
when cylinder pressure peaks at this position instead of sooner.
Want more info on 'real world' ignition timing?
This article from Australia is good:
https://dodgeforum.com/m_982171/tm.htm
