Can anybody help?
Old Sep 30, 2007 | 06:57 PM
campermama's Avatar
campermama
Default Can anybody help?
I have an 04 CTD 2500 with tow mirrors and heated as well.I noticed thedriver side mirror has started moving like it is loose when I am driving. I moved it so I can see inside/behind the mirror and I can see the rubber has come out of the wire "clamp" on one side and that is what is making it jiggle. Is there a way to take it apart or something to fix it?Thanks!!
Old Sep 30, 2007 | 07:38 PM
helopilot's Avatar
helopilot
Default RE: Can anybody help?
ORIGINAL: campermama
Go here and download the 3000+ page Dodge maintenance manual. It should give you all the info you need. It says Hemi on the link but it is for all engines.
http://www.summitvista.com/hemi
if that doesn't work, go to hemi truck club .com, no spaces, and you can download it off the left side menu at the bottom.
Old Sep 30, 2007 | 09:10 PM
campermama's Avatar
campermama
Perfect! Thank you very much!!!
Old Oct 1, 2007 | 12:24 PM
campermama's Avatar
campermama
Ok, I downloaded the manual but it doesn't say/show anything about the rubber piece behing the mirror that I can see appears to be coming off and possibly why the mirror is jiggling. Anybody know anything about this??
Thanks again!
Old Oct 1, 2007 | 02:46 PM
helopilot's Avatar
helopilot
Thanks again!
Did you see the pics on page 23-44? I am just trying to visualize what ruber piece you are talking about.
Old Oct 1, 2007 | 03:10 PM
campermama's Avatar
campermama
Yes I did. When I looked behind my mirror (I turned it to one side) it looks like the retaining clip goes all the way around and holds like a rubber boot under the retaining clip. I can see that one side of the rubber boot has come out from under the clip and I believe that iswhat is causing it to jiggle. The manual does not mention or show this rubber piece, that is why I am asking here if anybody else knows anything about it.
Old Oct 3, 2007 | 12:21 PM
campermama's Avatar
campermama
So I fixed my mirror, it just popped out of a clip so I popped it back in, but there is a rubber boot that was tucked in the retaining clip that is not longer in the clip and I don't see any wayof getting it back in. I am bummed about that since it obviously keeps the dirt out and I am a major desert rat.
Old Oct 3, 2007 | 02:01 PM
helopilot's Avatar
helopilot
Glad to hear you got part of it fixed, I wish I could help you with the other part.
