Tire Size... More Side Wall
Old Oct 7, 2007 | 03:50 PM
tommygun89's Avatar
tommygun89
Default Tire Size... More Side Wall
Currently running stock 275 60r20 and wanting to go w/ an AT tire but want somehting that has more side wall to give the tire a more fuller look. What size will do this?
I like the Cooper Zeon LTZ
Old Oct 7, 2007 | 04:11 PM
OldMoparMan's Avatar
OldMoparMan
Default RE: Tire Size... More Side Wall
The number that determines "height" in a tire is the middle number. That's your Sidewall Aspect.
If your tire size is 270-60r x 20, that means the sidewall aspect is 60% of 270, or 270 mm in tire width.
Simply: The height of the tire is 60% of it's width.
Using a tire that's a 270-70r x 20, would be slightly taller, but require recalibration of your speedometer with a programmer.
The math looks like this:
270 x 60% = 162mm from ground to rim's edge.
270 x 70% = 189mm from ground to rim's edge.
By changing your tire size by 10% of the aspect, you increase your vehicle height by 27mm (25mm is one inch).
Overall tire height by 54mm (side wall increases top and botton, so it's x2) 54mm, slightly more the 2 inches.
Old Oct 7, 2007 | 04:13 PM
OldMoparMan
Oh......keep in mind: A tire's actual size, when compared to the same size tire of another brand, can vary. Tire MFGers must have their tires within spec of actual size, by 7% of actual printed size.
So, theoretically, a tire can vary up to 14% from another brand tire of the same size, as that's 7% plus or minus. (One brand 7% plus, compared to another tire 7% minus, equals 14%)[:@]
Old Oct 7, 2007 | 04:28 PM
MoparRob's Avatar
MoparRob
Or just go buy a new set of 18" or smaller rims, makes the tires look like they gotta alot more meat to em!
Old Oct 7, 2007 | 07:37 PM
tommygun89's Avatar
tommygun89
anyone able to put a 305/50r20 AT tire w/o a lift or leveling kit?
Old Oct 7, 2007 | 07:39 PM
Max Power's Avatar
Max Power
When I want tire dimensions, I just go to tirerack.com, look up the size, and click on the specs link in the product detail page.
Old Oct 7, 2007 | 10:49 PM
marv02's Avatar
marv02
If I recall305 are 32.1 inch tires, stock tires are like32.99 tall. I seen 305 on a stock truck at a dealership before.
The tire you want go to are wider.
Old Oct 7, 2007 | 10:53 PM
marv02's Avatar
marv02
Try This link it will give you tire size http://www.ringpinion.com/Calc_RPM.aspx
And if you go to the tire manufactors page lot of times they will give you how wide the tires ECT, and the tire ratings Stuff..
Old Oct 8, 2007 | 06:17 AM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
This is what I use to keep my mind away from metric computations. Take the tire size, subtract the wheel size and divide by 2 to get the sidewall size, in inches.
http://www.dakota-truck.net/TIRECALC/tirecalc.html
Old Oct 8, 2007 | 08:05 AM
highline9's Avatar
highline9
I have these (cooper) on my truck...just put them on 2k miles ago...and love em...I would highly recomend them. I have the 275 60 R20, but had the option for 285 70 r20 from discount tire...I pd like $170 per tire.
ORIGINAL: tommygun89
