seat belt chime
Old Oct 8, 2007 | 10:26 PM
BAnders's Avatar
BAnders
Default seat belt chime
i have a 2004 ram, is there a way to disable the seatbelt chime?
Old Oct 8, 2007 | 10:40 PM
jmiddleton's Avatar
jmiddleton
Default RE: seat belt chime
Great question, unfortunately I don't have and answer, but it anyone does, please share. I have a 2007 and that chime is annoying as my wife's Toyota.
Old Oct 8, 2007 | 10:46 PM
HemiLonestar's Avatar
HemiLonestar
You can only disable the chime for when you're going down the road. The owner's manual tells you how to do that. The initial chime when you start it without your seatbelt on is unavoidable, can't be changed.
Old Oct 9, 2007 | 01:28 AM
///Matt's Avatar
///Matt
BUCKLE THE **** UP. [:@]
Old Oct 9, 2007 | 05:34 AM
hemiyellow's Avatar
hemiyellow
DC Insider
use the jump seat (center seat) seat belt and buckle it in the driver buckle lol...thats what i use to do in my truck
Old Oct 9, 2007 | 06:01 AM
Beezz27's Avatar
Beezz27
On my 05 the seat belt sensor was a closed loop sensor (sensor closed when the belt is plugged in) so all I had to do is unplug the connector under the drivers seat at the seat belt anchor point and put a jumper wire between the 2 terminals. However on my sisters 07 grand cherokee the sensor is an open loop system so all I had to do with her's was un plug the sensor. Now having said that I still reccomend WEARING the seat belt!
Old Oct 9, 2007 | 02:00 PM
Brother Rob's Avatar
Brother Rob
Retired Moderator
HemiLonestar, is correct. Check the manual. You can disable the chime, EXCEPT at start-up. I did mine. If you go through drive-thru's a lot, you need to do that.
Old Oct 9, 2007 | 02:25 PM
livetokite's Avatar
livetokite
friend of mine wrapped the seat belt around the back of his seat and buckled it.
but if you get pulled over that probably wouldn't be good.
Old Oct 10, 2007 | 12:05 AM
BAnders's Avatar
BAnders
i wear my seat belt, but for driving through my apts i dont put it on until i get out of the gate. i will check it out tomorrow
Old Oct 10, 2007 | 10:10 AM
BLACKTRX4's Avatar
BLACKTRX4
My truck currently does not have the alarm or the start up chime for the seat belt but I don't know how it got that way because I bought it used with it aready that way. The light does stay lit but no alarms what so ever.
