Car Alarm w/ Remote Start
I had a Clifford put on my 05 Hemi. Never had a problem. They are all good: Viper, Clifford, Python... They are all the SAME lol.... it is like a Dodge vs. Chrysler vs Jeep.... same stuff....www.directed.com. I do know they all will work for you in your truck. As long as your truck has an AUTO tranny. Just look at the site and find the key fob style you like and buy the setup from that company. Viper is sold my Best Buy Clifford and Python are generally sold be aftermarket shops. Like audio stores..ect. Hope this helps.
-R
-R
ORIGINAL: aefwolf
Hey Im trying to put a Car Alarm + Remote Strat on my 03 Dodge Ram 4 DR 4X4 Quad cab.
Any suggestions. maybe one easy to install, does anyone have some exsperience with this.
There are no decent ones that are easy to install. The cheap ones one ebay are just that cheap with no warranty. The electronics in these trucks are to susceptable to stray trons. I would suggest first finding a decent installer in your area and then see what he carries/installs. That way you get a good warranty on the system and the work. My local guy does Audiovox so I'm going with the Prestige system. DEI stuff is fine as well, but the quality of the work is the most important.
I had mine installed by a professional, and to date i haven't had any problems with it...The remote feature is great in extreme cold/hot weather.....Because then i don't have to go outside to start the vehicle
If you do get one, make sure you get one with the remote which tells you by vibrating that your vehicle has been tampered with....
.If you do get one, make sure you get one with the remote which tells you by vibrating that your vehicle has been tampered with....
ORIGINAL: NYPANAMA42
I had mine installed by a professional, and to date I haven't had any problems with it...The remote feature is great in extreme cold/hot weather.....Because then I don't have to go outside to start the vehicle .
OH Also get an extended rage antenna (if available). I can start mine from up to 1,000 feet Line of sight. (meaning in open air, no walls or obstructions). So it says anyways... never really tested it from THAT far away. I think the farthest I've tested was 500 feet and that's in the store.
-R
EDIT: Here is a link to a NICE remote start that works from a MILE AWAY! (where was this whenI got mine
) http://www.clifford.com/Products/Pro...?ProductID=701
Trending Topics
https://dodgeforum.com/m_972072/tm.htm
This has been a hot topic, as of late. I'm sure if you do a search, you can get even more info.
