Groaning from rear
Old Oct 10, 2007 | 10:04 PM
marv02's Avatar
marv02
Default RE: Groaning from rear
Gears should not make any kind of noise if they are replaced BUT higher the gear ratio more likey they will make some kind of nose do to the higher picth teeth on the gear set.
I was told Richman uses a harder metal compound so they are know to make a little noise.
I had a set in my 1981 power wagon they did not make any noise.
Old Oct 11, 2007 | 07:21 AM
OldMoparMan's Avatar
OldMoparMan
ORIGINAL: TBarCYa
OMM,
Thanks. I don't know if it's got a LSD although I doubt it does because I'm always spinning the inside tire when accelerating around a turn. Is there anywhere besides the glovebox where I could find RPO codes? I looked in the glovebox and under the hood and can't find a sticker with codes.
I'll stick a finger in her rear tomorrow and see what comes out... :-)
Not sure about others here, but I can't spin a single tire to save my life, with LSD. Even on the dry street...
Not sure about the RPO codes anywhere alse. I have build specs on a sticker in my glovebox. Your's will be the same, accept no "Anti-Spin Differe" line, but your gear ratio above it.
Old Oct 11, 2007 | 07:37 AM
OldMoparMan
ORIGINAL: HammerZ71
You got enough guesses on the first noise, so I'm gonna take a stab on the second one, the something loose going over bumps. Check your spare tire holder under the bed.
I'm gonna have to check that on my own truck. At first, I thought it was my trailer hitch insert rattling in the receiver. Then I found my spare trailer ball bouncing around in my aluminum bed-box. I never thought to see if the spare came loose...........[]
Old Oct 11, 2007 | 07:38 AM
TBarCYa's Avatar
TBarCYa
It looks like there used to be a sticker next to the latch but someone removed it. Do they stamp the RPO codes on the axle or is there a tag or something?
Old Oct 11, 2007 | 07:46 AM
OldMoparMan
There's a metal tag, but I believe that refers to ratio, not LSD or not. How'd that finger-stick-in-your-rear thing work out?
The other thing you can do, is send a request to these people, and they'll send you an entire build sheet on your vehicle.
http://www.dodge.com/wccsapp/univers...amp;category=U
Lastly, take your VIN to your local dealer and ask them. They can print a build spec sheet off for you while you wait.......
Old Oct 11, 2007 | 08:07 AM
TBarCYa's Avatar
TBarCYa
Still haven't done it. It rained all last nite and should continue throughtout today. I'll plan to check it tomorrow unless things clear up at some point.
Old Oct 11, 2007 | 09:32 AM
Duso02's Avatar
Duso02
ORIGINAL: OldMoparMan
ORIGINAL: TBarCYa
OMM,
Wow, I can do it easy as hell.
Old Oct 11, 2007 | 07:59 PM
TBarCYa's Avatar
TBarCYa
I got the build sheet from Dodge and no LSD for me. I may have to look into adding one but not any time soon.
