bearings bad?
Old Oct 11, 2007 | 10:26 PM
buffgator's Avatar
buffgator
Default RE: bearings bad?
ORIGINAL: marv02
Add some grind away to you mufffer bearing that mite help
yeah...over my head. I dont know what a muffler bearing is, but I think your onto something
Old Oct 11, 2007 | 10:47 PM
marv02's Avatar
marv02
It's on the left side of the bummper bushing over by the reset button look for high pressure grease fitting not the standered zerk fitting the other one.
Old Oct 11, 2007 | 10:49 PM
marv02's Avatar
marv02
If you want help dont give bad Info, or you get bad advice.
Old Oct 11, 2007 | 10:50 PM
buffgator's Avatar
buffgator
ORIGINAL: marv02
ok now your playing games with me. What bad info did I give?
Old Oct 11, 2007 | 10:53 PM
marv02's Avatar
marv02
ORIGINAL: buffgator
wait just kidding the sound does not go away when I apply breaks, but does get quiter. It is the loudest at around 1500 rpms.
OK I give what bad info.
Old Oct 11, 2007 | 10:56 PM
buffgator's Avatar
buffgator
hows that bad info. Last night at 10:30 I said I thought that it did stop when applying the breaks. This morning driving to work I payed attention and notive that I was wrong. Its not bad info its the truth.
Old Oct 11, 2007 | 11:02 PM
marv02's Avatar
marv02
When you said just Kidding it sounded like you were mising with me.
Jack up the side of the truck you think is bad grab hold of top and bottom of the tire and see if there a lot or some play in spin the tire ans listen to it and go from there I think the front wheel bearings are seprated from the gear set change you could just need new wheel bearing the joy of owning cars and trucks also check the half shats see if they worn out.
If you'r truck lifted you go thought half shaft faster do to high angles from the lift kit.
Old Oct 11, 2007 | 11:05 PM
buffgator's Avatar
buffgator
ok thank you very much
Old Oct 11, 2007 | 11:41 PM
NYPANAMA42's Avatar
NYPANAMA42
ORIGINAL: buffgator
o3 ram 1500 4x4 quad cab
I thought the bearings on our trucks were sealed, and wasn't to be changed, or messed with?
Old Oct 12, 2007 | 01:51 AM
marv02's Avatar
marv02
You replace the complete hub Assy.
