lift
Old Oct 18, 2007 | 10:15 PM
morepower29's Avatar
morepower29
Default lift
I was looking at a lift the other day and it said will fit 33's My stock 275/60/20's are 33" the lift is 2 1/2 front 1 1/2 or 2 in the rear I have an 07 QC Laramie 4X4 what to you guys think about this lift fitting 35's
Old Oct 18, 2007 | 10:34 PM
minnesotamopar's Avatar
minnesotamopar
Default RE: lift
The math works--you'll technically gain a half inch of clearance if your measurements are right on.
Also, IMHO you don't have much to worry about in the rear. They don't turn, and those wheel wells are HUGE!
--Matt
Old Oct 18, 2007 | 10:45 PM
tdmopar59's Avatar
tdmopar59
Default RE: lift
yea the only time you have to worry about the rear is big tires and a big load.... other than that you should be fine in the rear... in the front you might have slight rub at full lock other than that pretty good...
Old Oct 19, 2007 | 08:28 AM
typeo44's Avatar
typeo44
Default RE: lift
morepower29,
take before and after pics. I was looking at a similar set-up.
