Rear End Shutter???
Old Oct 22, 2007 | 01:06 AM
SLCHemi's Avatar
SLCHemi
Default RE: Rear End Shutter???
After reading this I took my 2500 out for a little spin and paid close attention. Unfortunately (or perhaps fortunately for me) I felt nothing but smooth, taking of straight, at a slight angle, or cranking it to turn around in a circle. I can say that after switching to 4.56 gears if I have it in 4WD (hi or low) if I try to turn on dry pavement it lurches a bit (more than with the factory 3.73's), but that's pretty normal as I understand it (the shop that did the work and the dealer all said the same thing). I wonder, if you were to try to replicate the issue on loose ground, like gravel or dirt does it do the same ? My thought is I wonder if your clutch pack is sticking or something ?? Just a guess...if it feels smooth on loose surface that could be as the loose surface is allowing the tires to slip so you don't feel it....
Old Oct 24, 2007 | 12:48 AM
Jzero69's Avatar
Jzero69
In Reference to the TSB you talked about. I have a 04 2500 that does the same thing and I have an ALLData account and have read the TSB you are talking about. It referred to drive line angle of the driveshaftif I'm not mistaken. Do to it being a 3/4 ton the rear springs are jacked up a little higher and stiffer. I believe there was a fix that the dealer could do to correct the angle. If you want I can look at it again when I get time and give you more info.
Old Oct 24, 2007 | 01:23 AM
Hessmonster's Avatar
Hessmonster
That would be awsome. Like I said I want to take it in and if I have the TSB it will make it a lot easier.
Old Oct 24, 2007 | 01:48 AM
abarmby's Avatar
abarmby
ORIGINAL: SLCHemi
Be careful of engaging 4wd and turning on dry pavement or good surfaces. It's a BIG NO NO !!!!
The transfer box WILL bind and it will be catastrophic for your Xfer box.
It will grenade all over the floor if you push it. Especially since those 4:56 gears will amplify the torque.
Somebdy did just that a while back on here.
I don't know your level of experience of 4wd but, it should only be engaged on surfaces where slipping is occuring.
This eases the stress on the transfer box causing it not to bind.
Al.
Old Oct 24, 2007 | 11:17 AM
SLCHemi's Avatar
SLCHemi
ORIGINAL: abarmby
Al.
[/quote]
Totaly agreed and hear ya...I noticed the "lurch" only once while driving in snow I hit a small patch of dry pavement (maybe 5 feet), definately good advice though. No 4wd on dry pavement.....I had a buddy a long time ago (clear back in high school) who claimed this was not true...he threw it in 4wd, cranked the wheel to turn around and SNAP!....took us the better part of a day and hundreds of his dollars to replace all the parts that he blew up!
Old Oct 24, 2007 | 12:49 PM
Jzero69's Avatar
Jzero69
Here is the TSB. Now it refers to trucks with a tandem drive shaft but it still might be applicable in this situation with the driveline angle.
Drivetrain - Launch Shudder
NUMBER: 03-003-04
GROUP: Differential & Drive Line
DATE: June 15, 2004SUBJECT:
Launch Shudder
OVERVIEW:
This bulletin involves adjusting the propeller shaft working angles.
MODELS:2003 - 2004 (DR) Ram Truck
NOTE : This bulletin applies to vehicles equipped with a two piece rear driveshaft.
SYMPTOM/CONDITION:
A vehicle may exhibit a drive line shudder or vibrations while accelerating from a stop. The condition is most noticeable under heavy throttle acceleration and is usually only present a low speeds (below 25 m.p.h.).
DIAGNOSIS:
Vehicles equipped with a two piece driveshaft are designed to minimize reaction forces which result from the universal joint transmitting torque at an angle. These forces can not be eliminated entirely because of the necessity to compromise joint angle selection between curb and design loading conditions. When subjected to this vibration, the vehicle experiences a shudder type disturbance, generally occurring less than 25 mph. This disturbance will increase as the suspension moves further from its design load (typically two front passengers). The forces are also torque sensitive, which means the disturbance, will be highest under wide open throttle.
U-joint angles change depending upon the amount of weight applied to the vehicle bed, therefore u-joint angle readings may need to be taken with different vehicle loads in order to obtain a satisfactory compromise. The vehicle should be evaluated under the loaded condition that produces the objectionable disturbance.
PARTS REQUIRED:
SPECIAL TOOLS/EQUIPMENT REQUIRED:
REPAIR PROCEDURE:
1.
Inspect the suspension and drive line for any signs of worn or damaged parts. Make the necessary repairs.
2.
Raise the vehicle on a hoist. The weight of the vehicle must be supported by the suspension. Make sure that the frame is as level as possible.
3.
Remove universal joint snap rings if equipped, so Inclinometer No. 7663 base sits flat.
4.
Rotate shaft until transmission/transfer case output yoke bearing is facing downward.
NOTE :Always take measurements from front to rear and on the same side of the vehicle.
5.
Place inclinometer on yoke bearing cap or pinion flange ring (A) parallel to the shaft. Center the bubble in sight glass and record measurement (Fig. 1).
This measurement will give you the transmission yoke Output Angle.
6.
Rotate propeller shaft 90 degrees and place Inclinometer on yoke bearing parallel to the shaft . Center the bubble in sight glass and record measurement. This measurement can also be taken at the rear end of the shaft (Fig. 2).
This measurement will give you the Front Propeller Shaft Angle.
7.
Rotate propeller shaft 90 degrees and place Inclinometer on yoke bearing parallel to the rear shaft and center the bubble in the sight glass and record measurement. This measurement can also be taken at the rear end of the shaft.
This measurement will give you the Rear Propeller Shaft Angle.
8.
Rotate propeller shaft 90 degrees and place inclinometer on rear axle pinion flange yoke bearing parallel to the shaft (Fig. 3). Center the bubble in sight glass and record measurement.
This measurement will give you the Pinion Flange Input Angle or Pinion Angle.
9.
To calculate the operating angle for the transmission output to front propeller shaft (A) (Fig. 4), subtract front propeller shaft angle from the transmission output shaft. To calculate the operating angle for the front to rear propeller shaft (B) (Fig. 4), subtract the front prop. rear propeller shaft angel from the front. To calculate the operating angle for the rear prop. shaft to pinion angle (C) (Fig. 4), subtract the pinion angle from the rear prop. shaft angle. The operating angles can be adjusted by moving the center carrier bearing up or down. The center bearing brackets, listed above, are available in a variety of heights. The working angles should be adjusted to provide the lowest angle possible for the output shaft to front propeller shaft, front propeller shaft to rear propeller shaft and rear propeller shaft to axle pinion. The angles must be below 3 degrees but must have a minimum angle of 1/2 degree to provide for universal joint lubrication. Determine which direction you need to move the center bearing to optimize the angles and install the appropriate bracket to obtain the minimum working angle, but still maintain at least 1/2 degree to assure that there will be some movement in the U-joint bearings (Fig. 4).
TORQUE SPECIFICATIONSPOLICY:
Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
FAILURE CODE:Disclaimer :This bulletin is supplied as technical information only and is not an authorization for repair.
Old Oct 24, 2007 | 12:51 PM
Jzero69's Avatar
Jzero69
There were pictures in that but they don't seem to be working.
Old Oct 24, 2007 | 05:54 PM
Hessmonster
thats awsome
Thank you
Old Oct 24, 2007 | 06:40 PM
Jzero69's Avatar
Jzero69
I'm going to try to post the pictures seperately that didn't load last time. Just mach the Fig. numbers to the directions above.
