Seat belt Bell (i want it off)
Old Oct 23, 2007 | 05:28 PM
zuggy7's Avatar
zuggy7
Default Seat belt Bell (i want it off)
Hello guys is ther a fuse or something to take off the seat belt bell ?
2007 dodge ram hemi quad long box
I work in construction and do alot of stop and go on job site all within a few hundred feet for each stop,so i don't need seat belt.
i get a head ache each time i hear the darn thing .
Please help.
Paul
Old Oct 23, 2007 | 05:36 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Seat belt Bell (i want it off)
In your manual it will tell you how to disable the chime.
Working off memory here I think it is
Start with seatbult on
Turn key on
unhook seatbelt
Connect seatbelt
unhook
connect
unhook
connect
Maybe turn key back off?
It is something along those lines and in the manual.
thehemiman12345's Avatar
thehemiman12345
thers a sequence that u gotta do.....something like turn the key, click the seatbelt in and out 3 times in a certian amounttime, then turn the key off.....
....i'm sure someone else will post what the exact sequence is.....
Old Oct 23, 2007 | 07:34 PM
SWOS Chief's Avatar
SWOS Chief
Yeah buddy of mine was showing me last night, he has an 07. It's in your owner manual along with how to disable the honk on lock feature and how to change the key fob lock to do all or one door with one press.
Old Oct 23, 2007 | 08:44 PM
Parts/Service's Avatar
Parts/Service
Try this......
The following sequence of events must occur within sixty (60) seconds of the ignition switch being placed in the On position in order for the programming to be completed successfully.
[ol][*]With all doors closed and the ignition switch in any position except On or Start, buckle the driver side front seat belt.[*]Turn the ignition switch to the On position and wait for the seatbelt indicator reminder function to conclude (about six seconds).[*]Unbuckle and buckle the driver side front seat belt three or more times, ending with the belt buckled.[*]Turn the ignition switch to any position except On or Start to toggle the beltminder feature from its current setting (from active to inactive, or from inactive to active). A single chime tone will provide an audible confirmation that the programming sequence has been successfully completed. [/ol]
Old Oct 23, 2007 | 11:04 PM
lewpuckett's Avatar
lewpuckett
+1 parts service. i did my 07 that way & it worked.
Old Oct 23, 2007 | 11:35 PM
tdmopar59's Avatar
tdmopar59
[sm=icon_rtfm.gif] gotta love my smiley buddies!
Old Oct 24, 2007 | 07:02 AM
teva_feet's Avatar
teva_feet
ORIGINAL: Parts/Service
Try this......
kick ***!!!! worked like a charm......no more stinkin beeping[8D]
thx for posting the instructions
Old Oct 29, 2007 | 07:38 PM
FSUHEMI's Avatar
FSUHEMI
i got rid of mine by resetting the pcm and unhooking the seat belt before i put the fuse back in.... didnt know i could do it that way, but im glad it worked
Old Oct 29, 2007 | 08:25 PM
walsh465's Avatar
walsh465
all i did was took my middle passenger seatbelt and put it into the driver one and tucked it in between the seat. problem solved
[/align]
