biggest boots on 06 and up
Old Oct 24, 2007 | 03:22 PM
derwood's Avatar
derwood
Default biggest boots on 06 and up
Wondering what the biggest tire you all have tried on stock 06's and up. Have searched but found most rides are pre 06 with cranked torsion bars. Any pics would be nice.
Old Oct 24, 2007 | 04:41 PM
SWOS Chief's Avatar
SWOS Chief
Default RE: biggest boots on 06 and up
I am putting 35's on mine with a 6" lift. Hammerz71 says you can do 35's with the 4" though. Hoping to put mine together this weekend and will be posting pics asap if you want to see.
Old Oct 24, 2007 | 05:20 PM
HammerZ71's Avatar
HammerZ71
Even though the front end is different, the result is still the same. 33" is max with no modifications.
35's are do-able with as little as a 2" level kit, but to be able to take full flexing and bouncing off road, a 4" suspension lift is more realistic.
Old Oct 29, 2007 | 01:46 AM
BIGHORNHEMI380's Avatar
BIGHORNHEMI380
im new on here. i just put on 305/55x 20 on my ram. they only rub if you have the wheel turned all the way.
Old Oct 29, 2007 | 09:34 AM
chongo's Avatar
chongo
I have an 07 and I put 305x70x17 on with no problems which come out to a 34.1 inch tire and I could go to 315's or 35's if I get the 2 inch coil spring spacers up front.
https://dodgeforum.com/m_1022157/tm.htm - Mine with 305's
Old Oct 29, 2007 | 10:33 AM
tdmopar59's Avatar
tdmopar59
chongo yours is a mega cab... that runs off the 2500 chassis it is higher stock than the normal 1500....
Old Oct 29, 2007 | 10:50 AM
chongo's Avatar
chongo
ORIGINAL: tdmopar59
Ah, learning new things everyday, thanks.
Old Oct 29, 2007 | 11:05 AM
derwood's Avatar
derwood
Decided to go with the 285/70-17 BFG AT KO's as they'll be about the same stock height as the 20's. As much as I wanted to cram the 315's in, might as well do it properly before things get broke including me!
