check engine light
Old Oct 26, 2007 | 04:43 PM
Kendawg74's Avatar
Kendawg74
Default check engine light
Im sure this has been asked a thousand times but I couldnt find anything on here... anyway my check engine lightcomes on and off and now it has been staying on. How do I retrieve a code by turning the ignition on and off? By the way I have a 2007 1500 thanks
Old Oct 27, 2007 | 10:36 AM
highline9's Avatar
highline9
Default RE: check engine light
On mine, an 02, it's off to on (assessories) three times and then leave it on assessories...should show you a code...if not, a local auto parts store will read it for free
Old Oct 28, 2007 | 10:19 AM
Wilbur Indy's Avatar
Wilbur Indy
I think this previous thread is what you are looking for, it has helped me a bunch of times
https://dodgeforum.com/m_225755/mpage_1/tm.htm#595000
Old Oct 28, 2007 | 11:02 AM
lewpuckett's Avatar
lewpuckett
{what they said}
Old Oct 29, 2007 | 11:23 AM
Kendawg74's Avatar
Kendawg74
the code came up for low oil pressure but my gauge reads fine and there has been no drop in performance or any unusual noises. Maybe a bad sensor? Where would it be located? Thanks again
Old Oct 29, 2007 | 12:21 PM
misplaced_rage's Avatar
misplaced_rage
hmm...not sure where the sensor would be at. make sure to check all your relays and fuses, one of them could be shorted or something of that nature. and just my .02 if you haven't already, I highly suggest getting either a Chilton's or Haynes manual for your truck. They've never steered me wrong.
Old Oct 29, 2007 | 01:23 PM
mileshuff's Avatar
mileshuff
A 2007 truck should still be under warranty. Take it to the dealer.
