Here come the problem's
Old Oct 29, 2007 | 09:57 AM
TANKZ400's Avatar
TANKZ400
Default Here come the problem's
Ok so i have a 2007 Dodge ram quad cab 5.7 thunder road and had to pull off the high way and get the truck to a dealership because i could not do over 50 without the truck feeling like it was going to come apart.
Here are the problem's
Horrible shaking at 50+
Window's dont go up sometime all four and the back window does not work sometime's as well
Rear end sound's like it's going to fall out when you put it in reverse
Check engine light is on
8900 Miles
Old Oct 29, 2007 | 10:02 AM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Here come the problem's
Have fun Chevy shopping.
Old Oct 29, 2007 | 10:04 AM
tdmopar59's Avatar
tdmopar59
lets not mention the C word.... now give it a chane... you just got it your still under warranty take it to the dealer and explain the problems... you gotta understand any truck could have problems my dad got a chevy in 03 and hates it to death had a lot more problems than that hes lookin at dodges now..... just see whats going on it shouldnt cost you anything
Old Oct 29, 2007 | 10:42 AM
TANKZ400's Avatar
TANKZ400
Ok but the truck is brand new i should not be having these problem's
But here is the update just got a call
The Mds system had a code for a soft ware glitch and it was making the check engine light come on and the truck to shake like hell
they have to re program the whole system and they said it should be good to go
and for the grinding noise they said it's the transmission actuators they are just realy loud
Old Oct 29, 2007 | 11:10 AM
HammerZ71's Avatar
HammerZ71
Is it me or do the '07's seem to have many more issues than previous years?
Seems to be an awful lot of posts with new trucks dying on the side of the road, PCM issues, tranny issues, bad vibrations, rattles, etc. A lot more than I can recall when the '06's came out, even though they had a brand new MDS system.
It's not just the 1500's either. My buddy works for the smallish city where he lives. They have acouple of 5.9 CTD's ranging from '99-'04 and I think two Duramax's. Anyway based on the performance of the Dodge diesels vs. the Chevy's they had, the City Mgr. buys two new 6.7 CTD's. My buddy says they are the biggest POS he's ever seen. They both have spent much more time at the dealer than in service. Everything from rotors to tranny issues to PCM problems. He said both currently are running (when they do run) with CEL's awaiting a second PCM update that the dealer says is forthcoming from Chrysler "any day now".
Old Nov 2, 2007 | 11:28 AM
TANKZ400's Avatar
TANKZ400
Ok so I get on the high way this morning and it all starts over again the truck feel's like it's going to come apart on the high way it's just shaking like crazy
Old Nov 2, 2007 | 11:55 AM
bwhite757's Avatar
bwhite757
Take it back to the dealership. With this severe of a problem, they're either going to get you fixed or get you a new truck. It does sound like a MDS issue they way you're talking, sounds like when the MDS engages at a certain RPM is when you have the problem. Worst case scenario they throw a new engine in there
Old Nov 2, 2007 | 12:51 PM
Pappy_FB's Avatar
Pappy_FB
Everytime you take it to the dealership make them give you a copy of what your complaint is and what they have done to correct it.
I dunno about the laws where you live but you can invoke the Lemon Law here in FL.
My advice is look up the Lemon Law and see what your options are.
And if the service manager doesn't want to give up the copies (services records)or acts dumb, ask to speak to his boss. Everyone has someone over them even the Dealership, keep going up the chain until you get satifaction.
Old Nov 2, 2007 | 03:48 PM
TANKZ400's Avatar
TANKZ400
Hopefully i will get to take it into the dealership on monday
Old Nov 2, 2007 | 04:20 PM
truckin151's Avatar
truckin151
I agree with Pappy, it sounds like the mds is just not kicking in when it suppose to, something with the programing is still off. You should take them for a test drive when you bring it back to the dealership so they can see/feel it first hand. Also have the same person (if you can) ride with you after they "fix" the problem so that there is no question to whether it was fixed or not.
As fot the transmission noise, my 05' is real noisy when I put it into reverse or drive, kind of has a grinding clunk to it but I was also told that it was just a normal sound.
