Normal sound? *vid*
Old Nov 4, 2007 | 12:38 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Default Normal sound? *vid*
The "dealer"(actually some 19 yr old kid that works there on a road test)said this sound is the exhaust and it's normal[:@]but i don't believe it....what do you guys think? Out of gear the sound doesn't happen...I can rev it to redline and it sounds great so that's why I think it's not the exhaust or the engine(valves/lifters) at all. The sound mainly happens after first gear and when slowly accelerating...any advice would be great. Are the trannies known to make this noise? It's a 07hemi with 500 miles on it
http://www.youtube.com/watch?v=HOy1cm5CcXsThe sound happens about 8 seconds into the vid...hopefully you can hear it over the wind noise.
Old Nov 4, 2007 | 12:59 AM
MoparRob's Avatar
MoparRob
Default RE: Normal sound? *vid*
I dont drive a Hemi but I havedriven them afew times and that definatly doesn't sound normal to me.. Does it get faster when the rpms get higher? or ifyou shift into neutral while moving does it still make the sound?
Old Nov 4, 2007 | 01:10 AM
buzzard217's Avatar
buzzard217
Look under the truck and see if the exhaust is hitting some where. It may not touch until the engine is a full load. The exhaust will flex some under load. I have seen this a lot with mini vans. If it does it worse at low gear excel or in a hill climb I would say theres a good chance the exhaust is hiting something.
Old Nov 4, 2007 | 01:44 AM
JD1500's Avatar
JD1500
Well, that is not normal, or acceptible. but other than that i am of no help sorry.
As stated before, check exhaust, and headers.
Old Nov 4, 2007 | 11:11 AM
MikeHTally's Avatar
MikeHTally
Does sound like an exhaust contact issue. Maybe a loose hanger? Tell the nineteen year old he needs to look for other work. Cop, maybe?
Old Nov 4, 2007 | 11:18 AM
tdmopar59's Avatar
tdmopar59
i couldnt hear it !!! o well if its a rattle like it says in the video i would imagine it being a messed up hanger or somthin....
Old Nov 4, 2007 | 11:39 AM
SeVeReDiStOrTiOn
Thanks for the replies guys...i'll check the exhaust right now. It doesn't seem to get faster with rpm's...if it does it's very slight. I'll also try the neutral thing....if it goes away does that mean it's the tranny?
Old Nov 4, 2007 | 12:24 PM
hemiyellow's Avatar
hemiyellow
DC Insider
sounds like an exhaust contact issue to me as well....how fast are you going when it happened and how much throttle?
Old Nov 4, 2007 | 04:41 PM
SeVeReDiStOrTiOn
In the video it started at 25ish at less then 1/4 throttle...if I let off or just hold enough throttle to maintain speed the sound goes away.
I looked at the exhaust and everything seems fine. I did move the nut retaining clip from the cat to exhaust manifold bolt away from the block...one was 1/16 in away from the block while the other three are resting against the flanges. But nope...the sound is still there[:@]I took it for a test drive and the tranny was holding first gear way too long...it never did that before even on cold mornings.
Oh and the truck is a 2wd single cab..
Old Nov 5, 2007 | 12:08 AM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
It sounds a lot like my K&N CAI when I stomp on it however from the video is it appearant you were not stomping on it.
