Old Aug 5, 2015, 09:51 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Guides
Print Wikipost
Reliability of 4.7 vs HEMI
Old Nov 4, 2007 | 08:24 PM
HammerZ71's Avatar
HammerZ71
Default RE: Reliability of 4.7 vs HEMI
10 MPG, that's crazy! I'm getting 13.8 - 14.2 in combination driving from my lifted Hemi that now weighs in at close to 7000 lbs.!!!
My 4.7 is getting me 21.9 right now (overhead read out only) I know only 67 milesis not a true test, but I was pleasently surprised, so far, especially since it's the 265 HP H.O. version and it's in a Jeep Grand Cherokee 4x4. Really pushes that mid size SUV quite nicely too, only mod that I can tell it has is a fairly new (judging by shine and condition) Maganflow exhaust ( well, at least the muffler isa Magnaflow).
Old Nov 4, 2007 | 10:22 PM
John  M's Avatar
John M
I get 10 mpg in town and I'm quite happy with it considering how I drive it. I like using all my power[sm=crossbonesgif.gif]
Old Nov 5, 2007 | 12:19 AM
topcop38's Avatar
topcop38
14.5 with my 4.7 mostly in town
Old Nov 5, 2007 | 12:23 AM
tdmopar59's Avatar
tdmopar59
yea i'm around 10 with this winter fuel bs and i try driving nice but i dont think it changes the mpg much... at least accoarding to the overhead bs'er!
Old Nov 5, 2007 | 05:04 AM
HankL's Avatar
HankL
Only widely discussed design problem on the 4.7 V8 has been the 'brown goo' at the oil filler tube.
4.7 has been re-designed for this year with twin sparkplugs, more torque and 5% better fuel economy...are you thinking of this new model or buying used?
5.7 has a longer history of problems and corrections. Even before released for production the cam bearing began failing and introduction of the 5.7 was delayed 3 years. First 3 years of production had 'Hemi Tick' noises due to sloppy fit of exhaust valve guides to valve stems...and Chrysler refused to issue a recall due to high $ cost. 5.7 has a very small distance from the top of the first piston ring groove to the crown of the piston (called 'ring land') and to protect this there is a special chemical coating (anodzing) that has given some problems and there have been postings of 5.7 engines failing both in and out of warranty connected to this piston weak spot. Also keep in mind the transmission & torque converter versions for the 5.7...both have had failures due to the higher torque loads at shifting (search 'Torque Management) and Chrysler's choice of part materials (plastic TC parts)
But a 5.7 with MDS will have better daily driving MPG than the older version of the 4.7 in normal driving...this is true both of official EPA tests and numerous owner reports. If the new 4.7 twin sparkplug version only has 5% better fuel economy the 5.7 will still be equal or better.
Old Nov 5, 2007 | 07:55 AM
topcop38's Avatar
topcop38
by "new" 4.7 i assume you're talking about '08s, right? mine is an '07 but i have no idea how many plugs it has, assuming there were 8.
Old Nov 5, 2007 | 08:01 AM
Wishbone's Avatar
Wishbone
I have a friend who is a Dodge mechanic. He told me the 3.7L is far and away the most reliable followed by the 4.7L then Hemi. Thought I think the "Hemi Tick" gave that engine a bad wrap.
Old Nov 5, 2007 | 08:52 AM
Hemiriden's Avatar
Hemiriden
ORIGINAL: HankL
I agree. I have the Hemi and have had 0 (Zero) problems with the HEMI engine except for the fact it is not a 6.1... but i've had 2 trannies and a torque converter put into the truck and have had a rear LSD diff rebuilt.... all under warranty though. Make sure you get a steel drive shaft and not aluminum or you can break that too... luckily i've not yet... but with the problems i've had behind the engine... i'm just waiting.... mine IS an 05 and i think they build a stronger tranny for 06 and newer...also i tow 6-8k trailer every day so it puts a little more stress on the power train then normal....
