GCWR?
Old Nov 6, 2007 | 11:26 AM
ScottJ175's Avatar
ScottJ175
Default GCWR?
I've looked on my door sticker and in my glove box and can't find a GCWR rating.
I went to Dodge's site and for my configuration (Quad cab, 4.7L, auto, 4X4, 3.9 ratio) two values are listed. The only difference between the two is the payload rating and I can't find that either.
I have e-mailed Dodge requesting my build sheet.
Old Nov 6, 2007 | 04:59 PM
ScottJ175's Avatar
ScottJ175
Default RE: GCWR?
Here's the source of my confusion. The 3.92 axle is listed twice: http://www-5.dodge.com/towing5/D/veh...c+Transmission
2003 dodge ram 1500 pickup 1500 SLT, QUAD CAB, 4WD, 6.25 FT Bed, 5-45RFE Five-Speed Automatic Transmission, 4.7L Magnum(R) V8 Engine:
With 3.92 Axle Ratio Axle Ratio [i] You Can Tow 6050 lbs
Gross Vehicle Weight Rating (GVWR) [i] = 6650 lbs
Payload [i] = 1324 lbs
Curb Weight [i] = 5326 lbs
Curb Weight Front/Rear = 3076 lbs/3076 lbs
GAWR Front/Rear [i] = 3900 lbs/3900 lbs
Gross Combination Weight Rating (GCWR) [i] = 11500 lbs
With 3.55 Axle Ratio Axle Ratio [i] You Can Tow 6100 lbs[/b]
Payload [i] = 1375 lbs
Curb Weight [i] = 5275 lbs
Curb Weight Front/Rear = 3057 lbs/3057 lbs
With 3.92 Axle Ratio Axle Ratio [i] You Can Tow 7100 lbs[/b]
Gross Combination Weight Rating (GCWR) [i] = 12500 lbs
Old Nov 7, 2007 | 12:37 AM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
Default RE: GCWR?
I have nothing to back this theory but it looks like the first 3.92 is a typo.
Old Nov 7, 2007 | 10:19 AM
oefootball_70's Avatar
oefootball_70
Default RE: GCWR?
while we are talking about gears, how much does it cost to upgrade to say a 3.92 or 4.10?
Old Nov 7, 2007 | 10:24 AM
kregier's Avatar
kregier
Default RE: GCWR?
Actually, I wonder if the first one is for a 4wd models and the second for 2wd even though they're both listed under 4wd.
Old Nov 7, 2007 | 10:33 AM
tdmopar59's Avatar
tdmopar59
Default RE: GCWR?
ORIGINAL: oefootball_70
that is to small of a jump to justify the cost... maybe if you went with 4.56's it would be worth it.... it aint cheap though.. especially for a 4x4
Old Nov 7, 2007 | 05:28 PM
ScottJ175's Avatar
ScottJ175
Default RE: GCWR?
I think I figured out the two different ratings for the 3.92 ratio. Judging from the charts on this page the 20" wheels make the difference: http://dodgeram.info/2003/load-tow/1500.html
Old Nov 7, 2007 | 05:48 PM
drhunter's Avatar
drhunter
Default RE: GCWR?
Man this is confusing. I looked up my truck and pretty much get the same thing. There is an infamous equipment identification sticker which is suppose to tell you what your axle ratio is butI cant even find it on my truck and I bought it new. Wherethe heck is it? You will see the 3.92 is listed twice again for a 2005 model below.
2005 dodge ram 1500 pickup 1500 SLT, QUAD CAB, 2WD, 6.25 FT Bed, 5-Speed Automatic 545RFE Transmission, 4.7L Magnum(R) V8 Engine:
With 3.92 Axle Ratio Axle Ratio [i] You Can Tow 6350 lbs
Payload [i] = 1672 lbs
Curb Weight [i] = 4978 lbs
Curb Weight Front/Rear = 2938 lbs/2938 lbs
GAWR Front/Rear [i] = 3700 lbs/3900 lbs
With 3.55 Axle Ratio Axle Ratio [i] You Can Tow 6450 lbs[/b]
Payload [i] = 1740 lbs
Curb Weight [i] = 4910 lbs
Curb Weight Front/Rear = 2910 lbs/2910 lbs
With 3.92 Axle Ratio Axle Ratio [i] You Can Tow 7450 lbs[/b]
Old Nov 7, 2007 | 05:52 PM
ScottJ175's Avatar
ScottJ175
Default RE: GCWR?
ORIGINAL: drhunter
Look in your glove box for the equipment sticker.
See above for the different GCWR ratings for 3.92. Looks like 20" wheels cost you 1,000 pounds tow rating.
Old Nov 8, 2007 | 09:29 AM
drhunter's Avatar
drhunter
Default RE: GCWR?
I cleaned out my glove compartment looking for it and its not there. Can you explain to me how 3" bigger wheels cost a person 1,000 pounds of tow rating?
