stuck in 4 wheel drive
Old Nov 6, 2007 | 01:44 PM
Big Momma 2008's Avatar
Big Momma 2008
Default stuck in 4 wheel drive
I have a 2002 Ram 1500 4x4 - and had to put it in 4 wheel drive to keep from sliding in the rain. That was 2 weeks ago. Well it won't disengage. I was told to just put it in reverse and just drive it backwards until it comes out.
It has 130k and I can not afford to take it to the shop just yet. Any ideas?
Thanks.
Old Nov 6, 2007 | 02:04 PM
kregier's Avatar
kregier
Default RE: stuck in 4 wheel drive
Have you tried shifting into 4 low, drive a few feet and then shifting back to 2wd? Are you sure it's still in 4x4, and it's not just the sensor thinks it is so the indicator light is on?
Old Nov 6, 2007 | 02:14 PM
Big Momma 2008
I tried that. You can really only drive now in 4low. It grinds terribly in 2w. It needed a new transmission at 24K and the power steering & rack in pion went at 30K - it was good until 95K when the rear differential went. The A/C just went at 120K. So I'm kinda of done putting $$$ in it.
Old Nov 6, 2007 | 02:51 PM
bwhite757's Avatar
bwhite757
I may be WAY off here, I had this problem with my 92 Blazer back in the day, turned out to be clogged vacuum hoses. Might be worth checking...
Old Nov 6, 2007 | 02:57 PM
Big Momma 2008
Thanks.
Old Nov 6, 2007 | 04:00 PM
John  M's Avatar
John M
You're in 4 low and not 4 high? If so, it always grinds going from 4lo to 2hi. You're supposed to pull it semi-quick from 4low to 2hi while rolling 2-4 mph.
bwhite757 - these trucks don't use the thermostatic type switches to engage 4wd like the GM products of the 90s did. My last truck was a 92 GMC 4wd that had only 105k miles when I sold it earlier this year.
