Type of Greese and lube
Old Nov 9, 2007 | 08:56 PM
tonymd's Avatar
tonymd
Default Type of Greese and lube
Im about to do my 1st maintence ever on my 07 ram 2500. I got some super tech general purpose greese lithium basedfor the drive trainis that right?
Also it says to lube the lie rods how is that done? This is my 1st truck.
Old Nov 10, 2007 | 10:22 AM
tonymd's Avatar
tonymd
Default RE: Type of Greese and lube
Anyone?
Old Nov 10, 2007 | 10:36 AM
tdmopar59's Avatar
tdmopar59
there are little grease fittngs on the bottom.... it s real easy as long as you have a grease gun and as long as you have grease... its fine they cantr really change to much in grease! lol
Old Nov 10, 2007 | 10:40 AM
tonymd's Avatar
tonymd
Thanks. So the drivetrane takes the same greese as the tie rods?
Old Nov 10, 2007 | 10:41 AM
tdmopar59's Avatar
tdmopar59
Where at on the drivetrain?
Old Nov 10, 2007 | 11:08 AM
tonymd's Avatar
tonymd
Says lubricate outer tie rod ends.
Old Nov 10, 2007 | 11:55 AM
tdmopar59's Avatar
tdmopar59
yea.... lubricate them with grease... and you said "the drivetrain takes the same grease also" and i said where at on the drivetrain... just the tie rod end?
Old Nov 10, 2007 | 02:43 PM
tonymd's Avatar
tonymd
Thanks for the reply. I ment to say drive shaft not drive trane.
Old Nov 10, 2007 | 04:35 PM
Gone Fishin's Avatar
Gone Fishin
Go to this shortcut.https://dodgeforum.com/m_356083/tm.htm
Drew did a great write up on the front drive shaft. You'll need to get a grease needle--looks like a BIG hypodermic needle with a grease zerk on the end. Oh yah, and a flashlight
