Radio
Old Nov 13, 2007 | 08:39 AM
luis_defreitas's Avatar
luis_defreitas
Default Radio
Hi guys!
I just install a new aftermarket radio and I only found power thru the red cable?!!! The issue thatI have now is that the radio is always on I guess thatI missed the right connection. Can any one give an advice?
btw: I already check the service manual but to be honest I didnt see it or I didnt understand it LOL
Old Nov 13, 2007 | 09:22 AM
tdmopar59's Avatar
tdmopar59
Default RE: Radio
did you use one of those adapters to hook it up?
Old Nov 13, 2007 | 10:11 AM
Tailbuster's Avatar
Tailbuster
Default RE: Radio
I would never hook up an aftermarket radio in a newer generation vehicle without buying the adapter. It saves so much time and eliminates the problem you are having now. Start over and buy the adapter. Its available on Crutchfield.com or go to your local Best Buy or Circuit City.
Old Nov 13, 2007 | 10:32 AM
spud11's Avatar
spud11
Default RE: Radio
Oly problem being that if he cut the wires from the stock connector too short. By the way, I did my radio no problem without an adapter. If you can't get the stock connector together, what year is your truck I have a a wiring diagram for '02-'05.
Old Nov 13, 2007 | 01:20 PM
Parts/Service's Avatar
Parts/Service
Default RE: Radio
Look for 2 wires that are grey with a red stripe, either one of these could be used for fused power.
Old Nov 13, 2007 | 02:13 PM
luis_defreitas
Default RE: Radio
I used the adapter but I could not find the right cable so I put it together! I will look again... Thanks guys
Old Nov 13, 2007 | 02:17 PM
SinCity R/T's Avatar
SinCity R/T
Default RE: Radio
I'm not sure what the particular wire is for your year/model, but I'd highly recommend hopping over to Radio Shack/Wally World/etc. and pick up a cheap multimeter so you can find out which wire is +12VDC only when the key is turned to ON. You shouldn't have to worry aboutchecking too many wires- most standard radios have 4x pairs of +/- for speakers, 1x antenna line, 1x ground line, 1x "always on" 12VDC line for the clock/presets, and 1x "ignition/ON" +12VDC for primary power... Once you've eliminated the usual suspects you shouldn't have much left, other wires may be present for power antenna, remote amp control, dash dimmer control, etc.
Old Nov 14, 2007 | 02:27 AM
storm910's Avatar
storm910
Default RE: Radio
in the 06+ dodges there is no switched 12v wire in the radio harness. keyed power on these years is controlled through the can-bus system, so to get switched power you need to use a can-bus module or tag power somewhere else. there is usually switched power on the left cig lighter below the radio, i believe it's a pink/yellow wire. hope this helps!
Old Nov 14, 2007 | 09:37 AM
luis_defreitas
Default RE: Radio
ORIGINAL: storm910
u are totally RIGHT!!!
when i bought the adapter i didnt even look at the documentation and I didnt install the bus-can adapter. Well, I just installed and is working like a charm so thanks so much guys for your help! I will post pics in a new Post.
