C-Clip Pictures?
Old Nov 17, 2007 | 06:40 PM
bigley12345's Avatar
bigley12345
Default C-Clip Pictures?
Earlier today i changed the fluid in the front and rear differentials. it is an '03 and it does have the LSD. i found a piece of metal. i am wondering if anyone can tell me what this looks like
[IMG]local://upfiles/47023/B6CB373217DD4CF9AC69A09FBA9DA311.jpg[/IMG]
Old Nov 17, 2007 | 06:43 PM
JD1500's Avatar
JD1500
Default RE: C-Clip Pictures?
I cant tell you what it is, sorry, but i can tell you...
Get it looked at. there is not supposed to be loose metal in the rear
Old Nov 17, 2007 | 06:49 PM
helopilot's Avatar
helopilot
ORIGINAL: bigley12345
That is indeed the clutch retaining clip. Check to make sure there is no damage and you might want to swap out to an aftermarket unit if you are not under warranty.
Old Nov 18, 2007 | 11:15 AM
chadmech28's Avatar
chadmech28
Chrysler has a repair kit for the c-clips out now it's like 15.00$ that is the way i would going before i change the housing. It wouldn't be a bad idea when your in there to change the carrier bearings. I have one i'm working on right now the whole job takes about 3 hours not a big deal.
Old Nov 18, 2007 | 04:01 PM
MoparRob's Avatar
MoparRob
search the forums for C-clip failures/ C-clip disasters
Old Nov 20, 2007 | 07:34 PM
DougieFresh1970's Avatar
DougieFresh1970
I just changed the rear differential gear lube and found two clips just like the clips found in the first post. The reason I change the lube is because of the loud noise the limited slip (trac lok LSD) system was makingwhile making sharpturns. Changing the lube and adding 4oz of the LSD additive did take the nosie completly away but I found those clips during the lube change. I found a few links on installation of LSD.
http://www.nagca.com/grandtech/traclokmadeeasy.htm
Im not looking forward to overhauling the differential. Im hoping the lube change will buy some time. Is the overhaul relatively easy? How many c-clips are therein the rear diff system?
Doug
Old Nov 20, 2007 | 08:06 PM
kx250frider617's Avatar
kx250frider617
if the clips didnt ruin any thing ur fine. just put the right additive in it. the mechanic at dodge said that at worst the only thing you'll notice is that when you go to burn out only one tire will spin, but same thing happen to mine and both still do.
Old Nov 20, 2007 | 08:07 PM
manogmin's Avatar
manogmin
well, it all depends on how long the clip has been broken and how many shavings you find. when i changed mine, there was enough to fill a small coffee cup. mine was under warranty so i paid 100 for a $3500 repair. that carrier bearing in mine was almost eaten clean thru. the fluid change may buy time, it may not, if the clip broke, not came out as a whole, it will eat into the bearing, and eventually the whole diff will fail. expensive thing to wait on. take care of it now if at all possible
Old Nov 20, 2007 | 08:12 PM
kx250frider617
yea luck for me it just dropped straight down to the magnet, didn't even scratch anything.
