Keyless entry question
Old Nov 25, 2007 | 04:59 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Default Keyless entry question
I can't seem to be able to turn the horn honk off when arming the factory alarm...is there a trick to it? From what i've read you're supposed to hold the lock button on the key for 4 to 10 seconds....then while still holding the lock button you push and hold the panic button (doesn't say for how long). Then the packet says to release both buttons at the same time. I tried it about a dozen times with no luck[:@]
Old Nov 25, 2007 | 07:57 PM
Parts/Service's Avatar
Parts/Service
Default RE: Keyless entry question
This is out of the 2006 manual. Hope it helps......
STANDARD PROCEDURE - RKE TRANSMITTER CUSTOMER PREFERENCES
AUTOMATIC (ROLLING) LOCKS
The rolling locks feature can be toggled ON/OFF by using a scan tool only.
HORN CHIRP DISABLING / ENABLING
The horn chirp can be toggled using a scan or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle.
To DISABLE (cancel) the horn chirp feature:
[ol][*]Enter the vehicle and close all doors.[*]Fasten the seat belt (this will cancel the seat belt chime).[*]Turn the ignition to the ON position.[*]Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the UNLOCK button. When a single chime is heard, release both buttons.[*]Turn the ignition OFF.[*]Turn the ignition ON or wait 60 seconds.[*]Test the horn chirp feature by pressing the LOCK button.
If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure.
To ENABLE the horn chirp feature, repeat the above procedure. [/ol]
OPTICAL CHIRP (FLASH) DISABLING / ENABLING
The optical chirp can be toggled using a scan tool or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle.
To DISABLE (cancel) the optical chirp feature:
[ol][*]Enter the vehicle and close all doors.[*]Fasten the seat belt (this will cancel the seat belt chime).[*]Turn the ignition to the ON position.[*]Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the PANIC button. When a single chime is heard, release both buttons.[*]Turn the ignition OFF.[*]Turn the ignition ON or wait 60 seconds.[*]Test the optical chirp feature by pressing the LOCK button.
To ENABLE the optical chirp feature, repeat the above procedure. [/ol]
UNLOCK SEQUENCE
The unlock sequence can be toggled using a scan tool or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle.
To toggle between Driver door first and Unlock all doors function:
[ol][*]Enter the vehicle and close all doors.[*]Fasten the seat belt (this will cancel the seat belt chime).[*]Turn the ignition to the ON position.[*]Press and hold the UNLOCK button for 4 seconds. Within 6 seconds with the UNLOCK button still depressed, press the LOCK button. When a single chime is heard, release both buttons.[*]Turn the ignition OFF.[*]Turn the ignition ON or wait 60 seconds.
To toggle this feature, repeat the above procedure.[/ol]
Old Nov 26, 2007 | 01:32 PM
slapshot12's Avatar
slapshot12
There has been some discussion about this in the past. It seems that the proceedure works for some and not for others. It worked fine on my 07, but it didn't on a a few other 07's.
Old Nov 26, 2007 | 10:07 PM
SeVeReDiStOrTiOn
Cool i'll try that..thanks guys
Old Nov 26, 2007 | 10:24 PM
SeVeReDiStOrTiOn
Crap...didn't work...i'll just have the dealer do it[:@]
Old Nov 27, 2007 | 10:31 PM
SeVeReDiStOrTiOn
I went to the dealer today and they programmed the horn off. If anyone else is interested they also said they could activate the daytime running lights (headlights come on when in gear but they're dimmer) and have the headlights come on when you turn your wipers on. I might do the DRL later...has anyone had that activated?
Old Apr 11, 2008 | 06:44 PM
Ironhead's Avatar
Ironhead
ORIGINAL: SeVeReDiStOrTiOn
That is the procedure I used on my 08
Old Apr 11, 2008 | 07:35 PM
HemiLonestar's Avatar
HemiLonestar
It's in the owner's manual and in the FSM.
Old Apr 11, 2008 | 09:43 PM
SeVeReDiStOrTiOn
^^^I know...the problem was that it doesn't work on a lot of 07's for some reason. The dealer had to use the starscan to turn it off..
Old Apr 11, 2008 | 09:54 PM
HighDuke1911's Avatar
HighDuke1911
oh, so we can get the parking lights on when the car is on and auto lights with wipers? also, can we program our locks to unlock the back doors when they ar opened instead of me having to hit unlock everytime?
