Lift for 07 Ram 1500
Old Jul 7, 2008 | 12:26 AM
  #21
srt4misfit's Avatar
srt4misfit
Default RE: Lift for 07 Ram 1500
Here's a pic of my '07 with 18' rockstars on 35' procomp extreme A/T
All I have done is a 2.5' leveling kit.
[IMG]local://upfiles/90925/44E33E1F943E459B98DCD718DD572A53.jpg[/IMG]
Old Jul 7, 2008 | 08:31 PM
  #22
Cappy's Avatar
Cappy
I'm staying away from the leveling kit because I want new springs. Drivers side is sagging abit and I'd like a stiffer rate or maybe a progressive one. My truck stays on the street so I'm looking for it to perform like it.
Your truck does look nice.
Old Jul 8, 2008 | 08:10 AM
  #23
PowerDodge07's Avatar
PowerDodge07
Hey srt4misfit, did you have any rubbing trouble with the 35s and rockstars with just the leveling kit?
Old Oct 28, 2008 | 04:39 PM
  #24
ninja4077's Avatar
ninja4077
Default 2x4
Why don't they make any kind of lift kits for a 2X4? I don't do any off roading or towing so I didn't feel the need for a 4X4, but I want to raise it about 2-3 inches. Anyone have a solution?
Old Oct 28, 2008 | 04:55 PM
  #25
TheBaker's Avatar
TheBaker
Get a levling kit/coil spring spacer for the front. Levels out the front, raising it about 2 inches. My 08 2wd is in the shop getting that done right now. That gets the leveled look, then do a body lift for a simple all around lift. You have an 08 like I do, and Performance Accessories makes a 3'' body lift for about 350$, opposed to about 700$ for a spindle lift. Not to mention, about 500$ for the body lift installation compared to probably over 1000$ on the suspension lift. Also, the leveling kit is only about 175$ installed. Just make sure to get an alignment afterwards.
Old Oct 28, 2008 | 04:57 PM
  #26
ninja4077's Avatar
ninja4077
Thanks Baker. I appreciate the info.
Old Oct 28, 2008 | 05:01 PM
  #27
TheBaker's Avatar
TheBaker
No problem, and i'll try to post up some before and after pics with the leveling kit on. I also threw some shock boots on to add some color.
Old Jan 19, 2009 | 07:34 PM
  #28
jamddyer's Avatar
jamddyer
Default 6" suspension lift
i have a 03 dodge ram 1500 4wd 4 door. i am wanting to put a 6" suspension lift on my truck. i was wanting to know is there any modifications that have to be done? and also do yall think my truck would look alright with some 35s on 17" wheels? also what brand lifts would you recommend?
