lifted without a lift??
i have been looking into it and was wondering if i were to get a "leveling kit" that is adjustable to three inches and an add a leaf in the back, it would be higher right, well, how would that affect the front drive line?? like wear, and yes i know that it will put things a little out of line, and mess up geometry and such, but in real world application what am i looking at?
A leveling kit is not adjustable unless you have torsion bar's I dont know what year your truck is so i dont know if you have them or no and just adding a leaf in the back is only giong to make your ride stiffer not give you any lift you would have to get your spring's rearched just get a 4 inch lift. what are you trying to achieve
Yes you need an alignment after raising the front.. Even if you only crank them and not install new keys. And I am pretty sure that you can get "helper springs" leafs that will raise your truck up. Or you could always buy the blocks...(that way your ride wont get stiffer).
you can get the keys to raise the front up 2.5", but you can turn those down if you want and not get that much lift (so the local truck shop tells me) and you can also put blocks/shims under the rear springs to give you some rear lift. if you go max lift, i'd get new shocks and an alignment. it's kinda like wearing a rubber...there's always the chance that it could break, but don't let that stop you....just enjoy
ORIGINAL: sa1765
HAHAHAHHAHAH
Trending Topics
ORIGINAL: manogmin
add a leaf will raise the rear of the truck average 2" on most, and i have an 03 that is pictured and my sig states that it is a 4x4.
and that's not in yourSIG!
andwould some body tell me how a helper spring lift's your truck two inches, that's thefirsti've ever heard of thatand i've lifted alot of trucks
ORIGINAL: TANKZ400
03 is what i was looking for
ORIGINAL: manogmin
http://store.summitracing.com/partde...p;autoview=sku
http://www.jcwhitney.com/autoparts/P...003426/c-10101
there are two different type of helper springs ones that mount to the top of the existing pack and others that mount on the bottom of the leaf pack...
The leveling keys work fine, they will stiffen up the front end a little, but not near asmuch as cranking the T-bars that far will. Use blocks in the rear, or better yet air bags. If you use helper springs strong enough to give you added lift in the rear, the ride will literally bounce your kidneys to death. And, you should get an alignment when lifting the front, especially anything over an inch or so...
