4hi and 4lo
Old Dec 2, 2007 | 05:37 PM
shah 303's Avatar
shah 303
Default 4hi and 4lo
i am kinda new to 2004 dodge ram 1500 hemi and i have a question what is 4hi and 4lo and how do i use it?
Old Dec 2, 2007 | 06:26 PM
adamwade's Avatar
adamwade
Default RE: 4hi and 4lo
Did the truck come with an owner's manual?
Old Dec 2, 2007 | 09:32 PM
shah 303's Avatar
shah 303
ORIGINAL: adamwade
well i didnt get it when i bought it.
Old Dec 2, 2007 | 09:54 PM
moparmutt's Avatar
moparmutt
You need to be stopped for 4 low. You can change from 2 to 4 high while rolling.
Old Dec 2, 2007 | 10:24 PM
07 Ram TRX4's Avatar
07 Ram TRX4
4 hi.. is for street driving in bad weather or general offroading.... 4 Lo... is when you need tons of power in crappy conditions and you don't need to go fast..
Old Dec 2, 2007 | 10:31 PM
big guy's Avatar
big guy
Switchinginto 4L. The transmission must be in neutral, travelling no faster than 2 to 3 mph.If you don't do this right it will grind like hell!
Dan
Old Dec 2, 2007 | 10:36 PM
ScottJ175's Avatar
ScottJ175
Basically 2 Hi, 4 Hi and 4 Lo are "gears" for your transfer case (like 1-6 plus reverse for a manual).
The transfer case sits behind the transmission and is connected by driveshafts to the rear and front axles.
In 2 Hi it sends 100% of engine power to the rear axle and the driveshaft to the front axle just free wheels. The gear ratio here is 1 to 1 so no additional gear reduction beyond that supplied by the transmission happens.
In 4 Hi the front driveshaft is engaged and 50% of engine power is sent to each axle. The gear ratiohere is again 1 to 1.
In 4 Lo the power is split 50% just like in 4 Hi but there's a lower gear ratio (2.72 to 1 in the New Process 241 case in my 2003) to give extra grunt on top of that supplied by the transmission.
Keep in mind the transfer case has no differential action allowing one axle to turn faster than the other (which must happen when turning) so it will tend to bind up when used on high traction surfaces like dry pavement. This isn't an issue on dirt, mud, rocks or snow where wheel slip can provide the differential action.
Old Dec 3, 2007 | 09:50 AM
sddunn2's Avatar
sddunn2
Great explaination scottj175 u the man !![sm=hail.gif]
Old Dec 3, 2007 | 11:23 AM
ScottJ175's Avatar
ScottJ175
ORIGINAL: sddunn2
Thanks. I decided to explain rather than offer a RTFM because it's good practice.
I've been a software developer for 10 years but also have 5 years behind the parts counter in my past so I'm used to having to explain technical stuff.
Old Dec 3, 2007 | 08:44 PM
shah 303's Avatar
shah 303
ORIGINAL: ScottJ175
it is great info and it helped me understanding what to use. keep it up!!!
