GPS Mounting
Old Dec 3, 2007 | 10:16 PM
JD1500's Avatar
JD1500
Default GPS Mounting
Anyone else use GPS? if so how did you mount it. Mine came with a window mount but it is short, so that puts it, approx. 1.5 miles from my seat . Just curious. i need an extended moutn, or a more permanent solution
And just an FYI, i just got a Magellan at costco for 179. spec. edition sold only there. its great. deleted maps of mexico and added text to speech. if your interesed (i dont work for them, promise)
Old Dec 3, 2007 | 11:15 PM
chongo's Avatar
chongo
Default RE: GPS Mounting
https://dodgeforum.com/m_1070480/tm.htm
if you look on the dash of the top picture you can see the gps mount on the dash right above the radio- barely - but I bought the Garmin C330 from Walmart and it came with a windshield mount and also a round peice that sticks to your dash then you mount the suction cup to it - I have had it up there for 1 week now and it has stayed up fine - it is in perfect view and I can reach it easy.
Old Dec 3, 2007 | 11:39 PM
JD1500's Avatar
JD1500
I do have that disk, thanks ill give it a try
Old Dec 4, 2007 | 12:04 AM
chongo's Avatar
chongo
Just mount the disk and I just licked the suction cup - don;t slobber on it - and it should hold without a problem
Old Dec 4, 2007 | 08:32 AM
Jus Cruisin's Avatar
Jus Cruisin
I used my Garmin Zumo in my '06 with the glass mount. Never had any troubles seeing or hearing. I know have the factory nav in my 08.
Old Dec 4, 2007 | 06:59 PM
kenihemi's Avatar
kenihemi
I used to put the mount in my cupholder.
Old Dec 5, 2007 | 07:03 AM
Jus Cruisin
Someone on the CorvetteForum used the bottom half of a bottle, mounted the suction adaptor to it and stuck that in the cup holder. Used the suction mount on the GPS to attach to the hand-made mount.
Old Dec 5, 2007 | 03:45 PM
bwhite757's Avatar
bwhite757
The GPS unit isn't there, but you can see the window mount, that's where I keep my digiwalker, it's within reach, and never have problems seeing or hearing it...
Old Dec 5, 2007 | 04:18 PM
Hemichief's Avatar
Hemichief
I mount mine on the L side of the windshield, next to the cab pillar. I use the suction cup it came with. Normally it would be an issue if you have to have it plugged in. However, the battery on mine lasts for quite some time so I dont need to do that.
Old Dec 7, 2007 | 09:51 PM
stratusguy02's Avatar
stratusguy02
I just bought a bracket from bracketron and will mount my magellan to that. I will post pics as soon as I get it in.
